Mercedes AMG F1 W05
Forza
238
Re: Mercedes AMG F1 W05
Jerez T01 - Day 2
muhammad-13
muhammad-13
Merc' using Steering Wheel LCD...
f1rules
f1rules
597
ecapox
I wonder why they use the neon free flow vis, which details out exactly what is happening, while other teams use the UV flow vis which isn't quite as bright and obvious to prying eyes? Not that we can't see what's happening in each scenario, but one is way more visible to journalists and prying eyes from other teams.
dans79
267
ecapox wrote:I wonder why they use the neon free flow vis, which details out exactly what is happening, while other teams use the UV flow vis which isn't quite as bright and obvious to prying eyes? Not that we can't see what's happening in each scenario, but one is way more visible to journalists and prying eyes from other teams.
counter intelligence! :lol:
201 105 104 9 9 7
e30ernest wrote: Could they be using a combination of both therefore creating that sound off throttle?
No, they'll be keeping the throttles open as far as they can and using the turbo unit to harvest energy, hence the 'hot blowing' type noise.
shotzski
Of the 97 laps Nico did, how many tyre change, and compounds did they use? Do we have a data on that? Interesting drivers weren't complaining about tyre performance
diego.liv
diego.liv
All these carbon pieces of a puzzle, are there 1)as past seasons 2)due to new internal packaging 3)maybe we'll see changes (i.e. cooling) in future?
http://www.formula1.com/wi/enlarge/0x0/ ... 29a328.jpg
EDIT: i recall only the (cooling purpose) piece under #KeepFightingMichael,
diego.liv
diego.liv
shotzski wrote:Of the 97 laps Nico did, how many tyre change, and compounds did they use? Do we have a data on that? Interesting drivers weren't complaining about tyre performance
http://www.omnicorse.it/magazine/34257/ ... ci-nel-run
PH:"Non abbiamo fatto un confronto diretto con gli pneumatici dello scorso anno...Le squadre ci avevano segnalato dei pattinamenti anche in quarta e quinta marcia nelle loro simulazioni...per cui abbiamo realizzato delle coperture con mescole più morbide e con una costruzione più resistente"
We haven't done a direct comparison with last year's tyres
...The teams informed us about 'skipping' in their simulations (is it correct?when you have too much torque but lack of grip to 'use' it) even in 4th & 5th gears...[due to the reduced (rear) downforce levels] we made tyres with softer compounds and a more resistent construction
thomin
I played around with one of the pictures. It's still not perfect, but you can make out some of the details. Maybe our experts here can see something, despite this being an early configuration that will no doubt change before the first race.
thomin
In this one, the diffusor is quite visible
FoxHound
55
In pictures 5 and 6 that forza kindly posted, you can clearly see the car leaning through the corners.
I have not seen this behaviour as pronounced as I have on the mercedes lineage starting with the W02.
JET set
ForMuLaOne
ForMuLaOne
FoxHound wrote:In pictures 5 and 6 that forza kindly posted, you can clearly see the car leaning through the corners.
I get your point. As i look closer i believe that this is just a change in camber. the car itself seems to stay horizontal while the wheels are angled. Maybe they improved the suspension in a way that keeps the car aero stable but now also helps the tires in an innovative way.
atanatizante
115
Last night on Sky Sports F1 (sorry if I misunderstood something in the process) :
1. Nico stated that Tuesday night they went to Brackley in order to repair the broken FW (and even reinforced it, we say) and then get back to Jerez on Wednesday morning at 6AM.
2. Ted said that Paddy Lowe complained him coz W05 is a little bit overweight ...
Jesus
thomin
On a different note, had Mercedes asked me to chime in on the livery, here's what the W05 could have ended up with:
