Ferrari F14T
gray41
Re: Ferrari F14T
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
charlex
-4
Re: R: Ferrari F14T
ahahha
but man...superb sound! super awesome acceleration fantastic video
Re: R: Ferrari F14T
charlex wrote:
ahahha
It sounds like tuner car escaped from the fast and the furious. Love it!
F1.Ru
21
Re: Ferrari F14T
Ferrari F138 versus F14 T - Overhead Analysis
This overhead drawing shows how Ferrari's new 2014 car, the F14 T (top) differs from their 2013 car, the F138 (bottom). Firstly, the flat nose cone (1) on the F14 T is shorter than that on the F138. The regulation changes mean that the front wing on the 2014 car is 75mm narrower on each side and that brings the endplates (2) directly in front of the front tyre. As a result, the endplates are more complex and twisted to the outside in order to divert air around the tyre more efficiently. The onboard camera position (3) is now defined by the regulations, so the mounting is further back than it was in 2013. Even so, Ferrari have mounted the cameras so that they have a positive aerodynamic influence in this area. Further back along the car you can see the new bridge vertical turning vanes (4) which are an evolution of the ones introduced at the end of 2013. Ferrari put a lot of effort into making the sidepods (5) as small as possible and from above they appear narrower in places than those on the F138 (indicated by the yellow spot). There is also a cut out area in the 'cola bottle' section (6) which makes them narrower still. Hot air exits through two big oval openings at the rear of the sidepods (7). These openings are placed very low down so that hot air exits towards the diffuser. At the very rear of the car, vertical pillars (8) have been used to support the rear wing, whilst the new rear wing endplates (9) are divided into two sections and feature several gills.
© Formula1.com
Formula One is a game.............. but not any ordinary game for me
ecapox
Re: Ferrari F14T
SchumacherM wrote:
ecapox wrote:What does "giving up at the rear" mean?
Snap oversteer/loss of rear grip/general lack of rear grip.
I was thinking something totally different. Makes sense! Thanks.
F1.Ru
21
Re: Ferrari F14T
Ferrari F138 versus F14 T - Side View Analysis
This drawing compares the side profiles of Ferrari's new 2014 car, the F14 T (top) with their 2013 car, the F138 (bottom). Like Force India and Sauber, Ferrari have adopted a 'double step' in the chassis in order to allow a large amount of air to flow under the car, whilst respecting the reduction in chassis height by 100mm to 525mm. As a result of this, there is a steep slope from the low flat nose (1) up to the top of the chassis (2). As the yellow line (3) highlights, the underside of the chassis follows the same shape as the top surface, enabling Ferrari to get plenty of air flowing under the chassis and towards the diffuser, despite the reduction in nose/chassis height. One surprising design aspect of the 2014 car is that the sidepods (4) are very similar in size to last year's - an impressive achievement given the extra cooling requirements of the new power units. The turbo intercooler and various other radiators and cooling systems are housed within the sidepods, so it's advantageous aerodynamically to have kept those small. Another change from last year is that the airbox intake (5) has a more triangular shape, whilst the engine cover (6) has a large fin section which features a small hot air exit for the clutch. Further back down the car, the rear wing is supported by two boomerang-shaped pillars (7), whilst the rear wing endplates (8) are a similar shape to those on last year's McLaren and feature several gills in the lower section. Finally, all the hot air from the sidepods exits through two big oval openings at the rear of the sidepods. These openings are placed very low down - lower even than on the new Red Bull RB10 - and will allow hot air to exit towards the diffuser.
© Formula1.com
Chuckjr
38
Re: Ferrari F14T
“The reason for that is the nose rules allow quite a lot of geometrical freedom. So you go off exploring that freedom. The reason there isn’t a single solution is it’s not actually that sensitive an area so there’s lots and lots of different solutions that work." --James Allison, Ferrari.
So according to one of the most respected engineers in the F1 paddock, all this differentiation between noses is actually not that big of a deal...?
Watching F1 since 1986.
Re: Ferrari F14T
Chuckjr wrote:“The reason for that is the nose rules allow quite a lot of geometrical freedom. So you go off exploring that freedom. The reason there isn’t a single solution is it’s not actually that sensitive an area so there’s lots and lots of different solutions that work." --James Allison, Ferrari.
If it wasn't a big deal teams wouldn't put so much effort into Blanchimont noses or Sabretooth noses. Of course it's an important area.
adrianjordan
Re: Ferrari F14T
F1.Ru wrote:Ferrari F138 versus F14 T - Side View Analysis
Image Image
© Formula1.com
Looking at that side view, this year's car looks so much better to my eyes...shame it looks so weird at the front from most every other angle!!
Favourite team: McLaren
Re: Ferrari F14T
'Important' and 'sensitive' are not the same thing.
Frafer
Frafer
Re: Ferrari F14T
do they need some tuning regarding brake-by-wire?
MarkedOne8
MarkedOne8
Re: Ferrari F14T
The Raikkonen's spin, as can be seen on the video above, is not oversteer related. Oversteering can't be that severe. To me, it looks like classic brake bias settings mistake. Too much on the front. If it's not bias, it's differential settings or just engine settings. Not aerodynamics related.
Possible too.
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F14T
Different for 2014 on the minor detail side are the barge boards & leading edge of the floor where you can see a bit of metal as well as the upright turning vanes at the leading edge of the Sidepod. The bargeboards are much more like Lotus from last year just without the slits, they're just much different than Ferrari have used the last few years. Same goes for leading edge of the floor. I'm interested to see how this area of the car develops. I'm not really expecting to see performance parts until Bahrain, but it's an interesting launch car.
Re: Ferrari F14T
Day 3
Forza
238
Re: Ferrari F14T
