ringo wrote:Abarth wrote:I can't believe that max power is at higher than 10500 min-1. Lower rews less friction, most time to inject and burn fuel. Unless they deliberately map the engine in a way that it doesn't use all of available fuel... But why should they do this? Driveability?
That is not the case with formula 1 engines. The friction to engine speed relationship is not linear. Friction can increase with speed then decrease as speed continues to increase.
don't agree
the losses in the N/A engine (that represent the difference between imep and bmep) are friction + 'pumping losses'
the 2014 F1 equivalents of these pumping losses are continually accounted (eg in the compressor, turbine, and crankshaft powers)
there seems no basis in the published data that I have found that the true friction varies with engine speed as much as you suggest
(yes, the pumping losses could do, and they are particularly difficult to capture by measurement)
also this true friction power is rather small in 2014 F1, hardly bigger than the compressor power needed at 10500 rpm
because of this, the compressor power should fall more (from 10500 to 11500 rpm) than the friction power would rise
the air massflow is proportionate to (ambient pressure+compressor-added) pressure (A)
the compressor power is proportionate to compressor-added pressure (B)
A will be made to fall proportionately to an rpm increase, so B will fall disproportionately
and so liberate more power at the turbine
