Mercedes AMG F1 W05
Richard
Richard
Re: Mercedes AMG F1 W05
Two pages of talk about gear ratio regs was useful, but distracting from the actual car. It's now over in the gear ratios discussion
:arrow: http://www.f1technical.net/forum/viewto ... ead#unread
Ferraripilot
21
theWPTformula wrote:I've done an explanation piece on the 'u' bend in the W05's diffuser if you're interested - http://richlandf1.com/?p=19386. Apologies if it has already been discussed, I'm afraid I haven't been up to speed on the forum lately!
I believe the only part you're missing might be to suggest the 'U' in the diffuser aids the adjacent sides of the diffuser with better extraction similarly to how tuned exhaust manifold runners effect their adjacent runner in extracting gases. Clever design based on simple theory.
It's a nice workaround, but I don't believe it'll be a big performance differentiator.
AlexT
AlexT
This year's regulation states that the starter motor hole in the diffuser must be either shut or if looking from the underside it's not visible. So its actually a clever interpretation of the rules, this way you can still have it open and at the same time it's legal. Other teams just have a hinged "door" that closes after you remove the starter
theWPTformula
50
Ah, my original theory was that this was the case but after asking @F1_Aero on Twitter (who I believe works for Mercedes now) he dismissed this idea.
So Mercedes will bring a new Nose to the last Tests. It will be even lower and shorter to interfere with the Front Wing even less according to AMuS.
Soo excited to see all the Updates this Week will bring.
theformula
I have been trying to work out what team F1_Aero on twitter works for haha! What makes you think he works for Merc now?
Hamilton's blessed with an ability to make a car do pretty much anything he wants - Mark Hughes
theWPTformula
50
theformula wrote: I have been trying to work out what team F1_Aero on twitter works for haha! What makes you think he works for Merc now?
It's a combination of things he has said over the past few months. He said he was moving late last year and he's been very quiet around all things Mercedes, basically! I hope he finds himself a happy home there.
mix2mix
mix2mix
it seems to me merc have new front wing end plate
mix2mix
mix2mix
RicerDude
27
Horizontal flow conditioners on the side pods.
Also is that a Lotusesque barge board?
mix2mix
mix2mix
Bahrain Test 2 2014 (Day 1) from AMuS
DAMNINice
37
It's also great to see, that they have decided to use the slimmest of their engine cover and sidepod configurations.
So they have tested all of them and they can use the slimmest of all! That's great!
REal men play with twins!
mix2mix wrote:http://images.scribblelive.com/2014/2/2 ... a2_800.jpg
Nope still the same ones. 2 bend plates with a horizontal vane attached to the latter.
Winter Testing 2014 - Session 3, Day 1 - Bahrain (27.02.2014)
