theWPTformula wrote:Re: Inverted keel.
Really like the design but I have an inkling that this is illegal. I seem to recall that the nose tip cross section must lie between the point above the trailing edge if the front wing main plane (neutral section) and a point somewhere beyond the front wing endplate line. Correct me if I'm wrong.
Lovely renders, too.
thanks very much.
Modeled the front steps as following all the rules, then did a 180 degree turn this back and redesigned the parties respecting the limits.
The nose that invert. the black area is the beginning of the nose.
I read the rules, and this approach is quite different and can be discussed and generate new ideas.
I do not know if it's legal or illegal wanted the opinion of you.
Thanks
