CBeck113 wrote:That's not quite accurate. Actually it would be more like the police giving you a second speedometer and saying THIS one is never allowed to show a reading which exceeds the speed limit. Then the police see that it indeed does show excessive values, and gives you a warning, which you ignore. So, who's fault is it?
That wouldn't be accurate though. Not in my country anyway. The 'law' only states the max speed on highways (or as indicated), not what speedometer you need to use. I think it's the same in F1 where the rule states the fuel flow max - not specifically that the fuel flow sensor is always correct and must be abided by (even if it isn't). I also don't think the FIA came and said *you must limit the fuel of car 3* - but more as in *we have reason to believe that your car 3 is running over the threshold as indicated by these numbers - we therefore advice you to lower it accoarding to these values [or risk an investigation post race where we might conclude when in breach of article x.y.z. your disqualifcation from the race].
Because of this, I'm not sure I agree, but perhaps there are also different view points to consider. I'm looking at it from a sporting perspective. The rules are clear in what fuel flow is allowed. This is undisputable. From a sporting perspective, it is also important that the rule can be enforced equally and accurately over all competitors. If Redbull is right in their argument that they were within the rule of using the allowed fuel flow is yet to be seen. If they indeed can prove this, IMO the FIA will have a lot to answer for. They can't be seen telling teams to run below what the rule states. If they do, they need to at least be sure that their reasoning is sound and doesn't breach the sporting rules. That being that all teams must confirm to the same rules.
I refuse to think that different sensors (calibrated differently) could and should result in different fuel-flow-max across cars. In an idea world - the sensor is accurate the therefore the rule undisputed. IMO it's up to Redbull to prove now that this is *not* the case (in their case). If this is true, I see a huge scandal awaiting for the FIA because it would put the sporting code in doubt.
