Measurements ARE calculations based on known data. The ECU knows fuel pressures and injector open and close times as it controls the fuel system in minute detail, it is therefore able to calculate the fuel flow rates better than a low res ultrasonic sensor!Pup wrote:The ECU only tells the engine components what to do. It doesn't measure, other than to accept feedback from other components, like, for example, the fuel flow meter.
And what makes you think that these "known" values are more accurate than the values that the FFM is measuring? The ECU attempts to let x ml of fuel into the combustion chamber by opening the valve for y ms at a pressure of z bar. The values x, y and z in theory are nice and accurate, in practice though, these will all have minute variance on them, partly because of physical reality, and partly because of electronic timing issues. There is absolutely no reason why you should trust the computation carried out here to be more accurate than the measurement taken by the FFM.djos wrote:Measurements ARE calculations based on known data. The ECU knows fuel pressures and injector open and close times as it controls the fuel system in minute detail, it is therefore able to calculate the fuel flow rates better than a low res ultrasonic sensor!Pup wrote:The ECU only tells the engine components what to do. It doesn't measure, other than to accept feedback from other components, like, for example, the fuel flow meter.
Ultrasonics certainly will have an error rate. The error rate is well specified and controlled. What makes you think that the un-specified and un-controlled error rates of the electro-mechanical system that is the ECU and the injectors are lower?djos wrote:As others have pointed out, ultrasonic measurement of fluids under pressure is subject to all sorts of issues from pressure waves, fuel density variations and air bubble content.
Ultrasonics simply are not able to be as accurate as measuring the physical goings on in the engine and fuel system under the extreme conditions of an F1 car.
Maybe, but there are 2 things going on here. How close were RB pushing it? Were they running at exactly 100Kg/h (by their measure)? 99.9, 99.5? If so can they be sure the engine is taking every variable into account? Fuel varies in viscosity naturally, and by temperature, this will effect how much is injected at a fixed pressure and temperature. Do they take that into account? If they do is their temperature monitoring system calibrated (with documentation to back it up). No? Then they cant rely on it either practically or legally, its that simple.djos wrote:Simple BB, F1 has been using electronic fuel injection since the 80's, the industry experience behind EFI system is simply mammoth and fuel metering has been brought to a very precise science.
I am 1000000000% confident that they ran all sorts of sims and tests for those high pressure injectors and weighted amount of fuel that went through them at any and all imaginable duty cycles, now this info together with the actual duty cycles and fuel rail pressure during the race IS THE ACCURATE INFO that is available to the team, the info from FFM, as I remember, IS NOT!beelsebob wrote:Ultrasonics certainly will have an error rate. The error rate is well specified and controlled. What makes you think that the un-specified and un-controlled error rates of the electro-mechanical system that is the ECU and the injectors are lower?djos wrote:As others have pointed out, ultrasonic measurement of fluids under pressure is subject to all sorts of issues from pressure waves, fuel density variations and air bubble content.
Are you? Why would you be confident of that? You're talking about a team that did only a very few real world laps before the season started. Why would they waste those laps measuring how much fuel was going into the engine, rather than trying to get it running reliably, or trying to get some aero data down.jz11 wrote:I am 1000000000% confident that they ran all sorts of sims and tests for those high pressure injectors and weighted amount of fuel that went through them at any and all imaginable duty cyclesbeelsebob wrote:Ultrasonics certainly will have an error rate. The error rate is well specified and controlled. What makes you think that the un-specified and un-controlled error rates of the electro-mechanical system that is the ECU and the injectors are lower?djos wrote:As others have pointed out, ultrasonic measurement of fluids under pressure is subject to all sorts of issues from pressure waves, fuel density variations and air bubble content.
Again, no it's not accurate info. What happens when a tiny bit of debris starts to block one of the injectors? What happens when a pressure wave increases the amount going into the engine. What happens when one of the solenoids is slightly out of calibration and opens the valve slightly further/for longer? What on earth makes you think that this is in any way accurate data?now this info together with the actual duty cycles and fuel rail pressure during the race IS THE ACCURATE INFO that is available to the team, the info from FFM, as I remember, IS NOT!
Except again, we're talking about a team that infamously could not do their homework.basically the team does this homework before the race
Are you saying that every single time the injector opens it injects the exactly correct amount of fuel? To within 0.25%? Sorry im not buying it. The error is usually a lot more than that, but does tend to average out over time. Car engines can operator seemly fine with even significantly more error than that, especially under load.jz11 wrote:I am 1000000000% confident that they ran all sorts of sims and tests for those high pressure injectors and weighted amount of fuel that went through them at any and all imaginable duty cycles, now this info together with the actual duty cycles and fuel rail pressure during the race IS THE ACCURATE INFO that is available to the team, the info from FFM, as I remember, IS NOT!beelsebob wrote:Ultrasonics certainly will have an error rate. The error rate is well specified and controlled. What makes you think that the un-specified and un-controlled error rates of the electro-mechanical system that is the ECU and the injectors are lower?djos wrote:As others have pointed out, ultrasonic measurement of fluids under pressure is subject to all sorts of issues from pressure waves, fuel density variations and air bubble content.
basically the team does this homework before the race, that is how they get to that 100kg/h limit in the first place, and then FIA steps in, introduces it's sort-of-working solution to monitor fuel flow and says - based on our data you run your engine too high, tune it down by this or that amount! that is it! now you have 1 car that got screwed up by following this directive, would you screw the other up as well?
and ECU doesn't give a rats ass about some ultrasonic flow meter, it doesn't care nor should it (because that FFM is there for the FIA, not a source of info for the ECU), it assumes the pressure is constant and works the injectors according to preset maps, that is it!
