A/ Im a Dan Riccardo Fan BoiChrisM40 wrote:I dont think the RB fanboys know what it is they are arguing for.
LOL? So, if things are that black and white, would you care to explain why did they bother to appeal? If you have been reading about the subject for months, you probably familiar with an interview with the head of Gill Sensors where he admitted they still had some issues, which he expected to have solve in the beginning of the championship, except that they wheren’t. And that’s the paddock’s word, aka: a factdans79 wrote:I was reading up on it MONTHS ago, long before any RBR fan cared about it.....
Lol....
Perhaps RB fan boys don't know what they are arguing for, but both of you abide by the same error, which is thinking like other teams fan boys, therefore being absolutely certain about the guilt. So let´s try the other way around. Let´s think of what conclusions to reach if the hearing happens to prove (April 14) that they complyed with the flow rate regs and where asked by the FIA to downtune their engine in one unfair manner? This is something both you should read: http://www.autosport.com/news/report.php/id/113033ChrisM40 wrote:I dont think the RB fanboys know what it is they are arguing for.
They ARE guilty! There is no debate about it, as the rule stands they are guilty because they ignored the FIA instructions, that in itself makes them guilty, whether they breached in the flow limit or not.ebare wrote:LOL? So, if things are that black and white, would you care to explain why did they bother to appeal? If you have been reading about the subject for months, you probably familiar with an interview with the head of Gill Sensors where he admitted they still had some issues, which he expected to have solve in the beginning of the championship, except that they wheren’t. And that’s the paddock’s word, aka: a factdans79 wrote:I was reading up on it MONTHS ago, long before any RBR fan cared about it.....
Lol....
Being given that the sensors could lead to some teams being unfairly impaired, how would they be assigned, by pure luck (or lack of it, to be precise), the shortest straw, the eyes of the costumer or what?
The thing is, you have no evidence that the FIA's solution is actually garbage.jz11 wrote:I'm no RB fanboy, but can look like one if someone is reading this thread, for me it's not about RB, it's about garbage solution that FIA implemented to police the issue, it could be Mercedes or Caterham instead of RB, I would still think and write the same thing
This IS the ying-yang-thread, so no need to complain! (Sorry for caps lock...and !)Pup wrote:Remarkable how no one can say anything in this thread without the fanboys reaching for their caps lock key. Meanwhile, over at Autosport, they're managing to have an actual technical discussion about the issue.
Embarrassing. If I were Stephen, I think I'd delete this entire thread.
Did you not read what others and I wrote earlier about standartised testing and calibration of such devices? Standartised testing is what it is - under certain conditions (which are stated in the standard) taken measurements are +/- X amount to a true measurement which is done via this other (whatever that may be) method, and that is it, that is what it says for an engineer, it doesn't say that the X will be true for every and all possible applications and situations, that error rate is true only for the conditions of the standard test. And this current application is the exception - because there are inconsistencies with the projected fuel flow models, not only RBs model, but pretty much all of them, those are facts, it is just that for others it is not a big deal, they have a work around, but for RB there apparently wasn't.beelsebob wrote:The thing is, you have no evidence that the FIA's solution is actually garbage.jz11 wrote:I'm no RB fanboy, but can look like one if someone is reading this thread, for me it's not about RB, it's about garbage solution that FIA implemented to police the issue, it could be Mercedes or Caterham instead of RB, I would still think and write the same thing
You have no evidence at all that the readings that RedBull are complaining about are actually inaccurate.
Don't get me wrong – if there's actually some evidence that the FFM does not accurately measure flow, then that's fine, but as it stands, there is none, and there's evidence that these devices have been tested to within ±0.25% accuracy.
second one is dodgy - because it mentions that rpm, but prior to that is still states that Q is in kilograms per hour.5.1.4 Fuel mass flow must not exceed 100kg/h.
5.1.5 Below 10500rpm the fuel mass flow must not exceed Q (kg/h) = 0.009 N(rpm)+ 5.5.
Urgh... NOjz11 wrote:Rule states - 100kg/h? so in theory you can have 500kg/h for 12 minutes and then stop the flow altogether and you will be compliant with the 100kg/h limit still, because which ever way you measure these 12 minutes, in 1h period with those 12min in it, the average flow will be 100kg/h. And this is where 10Hz and 5Hz come into the play.
No where is it stated, that's because it's stated as a maximum. That is, for all samples, at any time, that sample may not exceed the limit. It does not matter when you sample, because if *any* sample exceeds the limit, no matter when you took it, the rule has been broken.Now what happened was that FIA apparently chose to run the flow meter and measure (and by measure I mean they got an average every 1/10 of a second from readings that were taken 1000 times a second) the flow in 10Hz frequency - meaning, every 1/10 of second the flow must not exceed the 100kg/h, now where is that statement in the rules that it will be measured 10 times a second? And then, during the course of the race weekend they decide, upon numerous inconsistencies with the predicted flow models, decrease that measurement rate to 5 times a second, does that not rise any doubt in your mind about this rule at all?
Again, the average does not matter. The rule is about the maximum.Maybe (because we don't know what the appeal wording is) RB claim is that their average is still 100kg/h, but if you measure 5 times a second, you will get 2 readings of 150kg/h, 2 readings of 50kg/h and 1 reading of 100kg/h, so the average is still 100kg/h, but from FIA point of view - they have CONSISTENTLY exceeded the flow rate and are to be disqualified.
