Isn't the nose section a bit higher? The rule states no body work above the diagonal drawn from the nose tip to the chassis? How does this pass the test?1158 wrote:![]()
I think you've got a nice spot there, check Avocado's last pic1158 wrote:http://i162.photobucket.com/albums/t268 ... db7709.jpg
Is that just an optical illusion or is that a cooling vent like the Lotus has?
I looked at several side shots from AUS and the floor curls in that area but this looks different. I'm inclined to believe it is an illusion. Seems to me that would be a poor location and I can't tell if there is a channel in the floor running to the sidepod.
Edit: After looking around more I'm almost certain that is just the floor. Carry on.
No, you could be right; it could very well be a cooling outlet. While there doesn't appear to be anything similar on the other side of the car, the new engines and their turbo intercoolers mean an asymmetric cooling layout from one sidepod to the other isn't necessarily an "exotic" (read: unlikely) solution.1158 wrote:[...]
Teams are given either 25mm or 50mm, or something like that, I can't remember exactly, above the reference plane to do pretty much whatever they want.siskue2005 wrote:Isn't the nose section a bit higher? The rule states no body work above the diagonal drawn from the nose tip to the chassis? How does this pass the test?
Blows the diffuser.jagunx51 wrote:is that a slot ? ..... to where? what for ?
http://imageshack.com/a/img594/9183/g3q3.jpg
Diesel wrote:Blows the diffuser.jagunx51 wrote:is that a slot ? ..... to where? what for ?
https://twitter.com/SomersF1/status/4498252437086617601158 wrote:http://i162.photobucket.com/albums/t268 ... db7709.jpg
