langwadt wrote:xpensive wrote:Which they will be, but de-clutchable, all still within the rules.
5.1.6
The shaft must be designed so as to ensure that the shaft
assembly, the compressor and the turbine
always rotate about a common axis and
at the
same angular velocity
the mgu-h to turbo can be clutched, but the turbine to compressor can't
You guys are making the mistake of thinking the clutch part of the rules specifies only one clutch, and only one area. It says none of that. Besides, how would anyone at any point know that the angular velocity of the compressor and the turbine is the same?
Anyway, 5.2.4 basically negates 5.1.6. It's pretty ingenious how they offer the loophole in the section titled "Other means of propulsion and energy recovery" so as to make it sound like it's completely unrelated to the engine specification.
Why would you even mention the MGU-H may be clutched if there wasn't something shady going on?
The MGU-H must be solely mechanically linked to the exhaust turbine of a pressure charging
system. This mechanical link must be of fixed speed ratio to the exhaust turbine and may be
clutched.
All they had to say was...
system. This mechanical link must be of fixed speed ratio to the exhaust turbine.
Instead they throw in a completely unnecessary 4 words, "...and may be clutched."
Were I more suspicious type, I might be wondering if this championship was rigged on some level. But that seems preposterous to me.
