Ferrari F14T
miguelalvesreis
miguelalvesreis
Re: Ferrari F14T
Crucial_Xtreme wrote:
Cuky wrote:
As far as I understand it, Ferrari is using Marussia to test that solution and perfect it before they use it on their car.
They've(Marussia) had the solution since Bahrain and have improved upon it since then. I don't buy that Marussia simply testing & perfecting it for Ferrari. Ferrari has the resources to make & test the exhaust cover without needing a guinea pig. It wouldn't be the first time a customer team has jumped ahead of Ferrari with particular updates here & there. Just my opinion.
Maybe they need in this case. There is a greater risk, this year, due to max allowed number of engines and parts.
Keeping the heat on the exausts may lead to increased stress on the turbine. May happen that can not be accuratelly reproduced in the test bench.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F14T
The team is allowed straightline tests and there have been numerous test sessions, Spain & Silverstone where they could've test an exhaust cover. They have chose not to for one reason or another. I don't want to argue back & forth because I'm not privy to the teams plans and inner workings. But the team has had ample time to test such a solution themselves if they wished to do so. The benefits of an exhaust cover that works is something the F14 T needs in a bad way and one would think with their severe need to improve the car they would've introduced their own solution by now, unless of course they didn't truly think about implementing it until recently.
Kiril Varbanov
147
Re: Ferrari F14T
Detailed analysis of F14T by Mark Hughes feat. illustrations from G. Piola:
http://www.motorsportmagazine.com/f1/fe ... 4-secrets/
Another take from Mark on why the aerodynamic failures of the F14 T have led to a power vacuum at Ferrari - http://www1.skysports.com/f1/report/220 ... -the-f14-t (the video content may be limited to UK only)
monsi
monsi
Re: Ferrari F14T
Kiril Varbanov wrote:Detailed analysis of F14T by Mark Hughes feat. illustrations from G. Piola:
I don't fully follow the suggested conclusions of the first link. Any extra space from moving the oil tank would surely have been equally suitable for a mercedes style layout. If they have under-specced the compressor then I can't see how this logically follows as a conclusion from the oil tank movement, it could be a separate issue, perhaps resulting from losing an internal argument with the aero team. The video link highlights the potential balance problems that arise from the movement, which I can understand, the logical place to place fluid reservoirs of any size would be close to the CoG I would imagine. I can well understand the team dynamic issues that may have resulted though - if aero people have stomped over their colleagues to get their way, and it has not paid off at all then their internal reputation will be mud.
Two follow on issues to explore perhaps, the effect of the increase of the wheelbase, and the effect of having the reservoir well away from the CoG.
Re: Ferrari F14T
This artical from autosprint claims they had 1 ready for Canada but it was Blocked by the FIA.
http://autosprint.corrieredellosport.it ... ica/17743/
Re: Ferrari F14T
Another great artical on the different Ferrari Engine covers and what they might be trying to do.
http://www.blogf1.it/2014/07/29/cofano- ... mperatura/
BTW to emmepi27 ...do you write that blog ?
timbo
timbo
113
Re: Ferrari F14T
diffuser wrote:This artical from autosprint claims they had 1 ready for Canada but it was Blocked by the FIA.
The google translate returns "paint" for "vernice". Are there other meanings? E.g. insulation, cover etc?
emmepi27
emmepi27
141
Re: Ferrari F14T
diffuser wrote:Another great artical on the different Ferrari Engine covers and what they might be trying to do.
Yep! Only technical analysis!
In this article i speak about only of another hypothesis of the bigger cooling exit reason. I suppose that it is not only for cooling but also for aerodynamic reason (heat to help rear wing).
Re: Ferrari F14T
I've always seen "vernice" translated into varnish. At any rate we all understand it to be some substance resembling a coat of paint having heat shielding properties.
Re: Ferrari F14T
I like your stuff ...keep it up Bravo bravo!
Re: Ferrari F14T
Zircotech then?
Baffling why something similar wasn't there from day one to be honest.
timbo
timbo
113
Re: Ferrari F14T
PhillipM wrote:
diffuser wrote:
timbo wrote:The google translate returns "paint" for "vernice". Are there other meanings? E.g. insulation, cover etc?
Zircotech then?
Well, if it is really some kind of coating it is all more interesting that Marussia actually used some sort of wrapping around the pipes.
emmepi27
emmepi27
141
Re: Ferrari F14T
Hungarian front brake duct (Amus)
eslam1986
eslam1986
Re: Ferrari F14T
photo of Ferrari engine exhaust with heat cover in marussia car
George-Jung
George-Jung
Re: Ferrari F14T
But that is not a coating, but an exhaust insulation wrap..
