I am trying to understand the logic behind the design of this car.
In the front end, it looks like they are trying to use the nose to generate downforce instead of the wings. The nose tip is like a four by four. It has the pelican-bottom that narrows like a water drop as it goes back. The triple vanes by the front wheels try to move some more air underneath it. Top of the nose section seems to be curved inward (compare this to mclaren, ferrari, merc) which also supports my initial point. But the tip of the nose seems like it will just squeeze air into the middle of the front wing and create a lot of drag for no gain.
The front wing is pretty ugly, too. Single piece top wing is pretty flat and looks more like a flow conditioner. The middle stage of the lower wing looks just ridiculously thick towards the inside. The inner portion of the bottom assembly (white, shiny section) seems to be designed to move the air inwards. I suspect it will stall regularly.
Overall I'm very worried about this car's performance.
