That was the raised eyebrows thing ?
Fastener failure...
I really wish to refrain from going further off topic, but admittingly it begs for joking.CBeck113 wrote:They did that for the sponsor...if it wasn't planned it would have happened to Maldonado
It's not so much the strength of the cover, more a problem with pressure build up inside the cover. The air that enters the car through the side pods and other intakes needs go somewhere. If it can't exit the car quick enough it needs space inside the car to occupy. Engine cover failures like this are not uncommon, it's usually caused by the team tightening the body work and reducing the internal airflow without sufficiently increasing the size of the cooling exits. They almost always happen on the straights too, when the airflow in to the car would be at it's highest. If you keep squeezing a balloon without letting any air out, eventually it's going to pop.itix wrote:Damn that is a fine looking car from above...
What worries me is that this isn't the first time this happens.
They seriously need to strengthen their side pod covers
Not to mention that when DRS activates, it has a knock-on effect on the airflow over the engine cover, which drops in pressure. Lower pressure above the cover combined with higher pressure underneath can lead to such issues.Diesel wrote:It's not so much the strength of the cover, more a problem with pressure build up inside the cover. The air that enters the car through the side pods and other intakes needs go somewhere. If it can't exit the car quick enough it needs space inside the car to occupy. Engine cover failures like this are not uncommon, it's usually caused by the team tightening the body work and reducing the internal airflow without sufficiently increasing the size of the cooling exits. They almost always happen on the straights too, when the airflow in to the car would be at it's highest. If you keep squeezing a balloon without letting any air out, eventually it's going to pop.itix wrote:Damn that is a fine looking car from above...
Strengthening the deal means extra weight coming along. I personally think Lotus were searching the limit with how little strenghtening they can get away with.Yeah I got that bit... But if it is deemed aerodynamically beneficent to keep the airflow as it is, they have to strengthen the components rather than duct more of the air out from the side pods.
That is should for Monaco high downforce spec.zioture wrote:Test Barcellona day 2 Monkey seat.
https://pbs.twimg.com/media/CE4coZHXIAAWsjz.jpg:large
