Scuderia Ferrari SF15-T
Re: Scuderia Ferrari SF15-T
New F Wing and Cameras
TechF1
zioture wrote:https://scontent-vie1-1.xx.fbcdn.net/hp ... e=562D41C9
A comparison with old spec.
Wing looks like the Mercedes. Ferrari is pretty good at part turnover.
Over View Fw
lio007
320
https://pbs.twimg.com/media/CI_KCq1WIAAXFDx.jpg:large
Silverstone - Friday
Cuky
65
PlatinumZealot wrote:Wing looks like the Mercedes. Ferrari is pretty good at part turnover.
And not only that but after few long years they are sticking with parts they bring on. In Spain when they brought whole new package on the car they wasn't sure so they used both new and old to confirm which one works better. Otherwise whenever they brought few small changes here and there they never reverted to older spec.
You forgot to highlight the change of shape where the mainplane curls down to back of the neutral section :P.
Crucial_Xtreme
Crucial_Xtreme
404
Some images of the SF-15T Silverstone updates
The vortex generator on the edges of floor now have a curl/twist
The floor ahead of rear tyre has been modified
The VG below air intake has been changed to help divert dirty wheel wake air
A change to rear brake ducts as well
Silent Storm
Silent Storm
127
mclaren_mircea
mclaren_mircea
Ferrari abandoned some aerodynamic parts used in Silverstone. Take a look:
"La pinna verticale vista in Austria è già sparita: gli aerodinamici del Cavallino fanno un passo indietro. Macchine indietro tutta: la Ferrari in Ungheria ha tolto alcune soluzioni di micro-aerodinamica che avevano carettrizzato lo sviluppo della SF15-T in Austria e a Silverstone. E' il chiaro segno che certe modifiche sono state bocciate dopo la gara inglese. Sotto alla scocca (foto Effe 1 Tech), infatti, è scomparsa la paratia verticale che si era vista ai due bordi esterni del T-tray, tornando a qualcosa di già visto in precedenza, sebbene l'Hungaroring sia un impianto che richiede il massimo carico aerodinamico. Gli aerodinamici del Cavallino, quindi, hanno fatto qualche passo indietro per riprendere il filo di sviluppo della Rossa."
Source: http://www.omnicorse.it/magazine/61479/ ... ella-rossa
