Scuderia Ferrari SF15-T
Re: Scuderia Ferrari SF15-T
Hungaroring - Thursday
Silent Storm
Silent Storm
127
https://twitter.com/albrodpul/status/624316254560501761 Ferrari has rounded the edge of the flathead of the rear wing to reduce drag by releasing pressure. https://twitter.com/albrodpul/status/624268157730095108 Insulation around the ducts near the intercooler.
232
These are two different front wings.
Silent Storm wrote:https://twitter.com/albrodpul/status/624316254560501761
Weird thing to reduce drag at Hungaroring...
Silent Storm
Silent Storm
127
Similar to what Mercedes did with smaller monkey seat, Ferrari did it with the rear wing. As I said in W06 thread front grip is vital in Hungaroring even at the expense of slightly less rear grip.
Cuky
65
Might not be. They could be running with higher AoA on rear wing, so they cut small portion of it out to try and take off a bit of added drag that AoA produces.
Hungaroring - Friday
Vis AMuS
Tiny aero flick below the Marelli logo
Via @ScarbsF1
siskue2005
70
isnt the sidepod new? huge bulge over the claro logo
JDC123
JDC123
30
siskue2005 wrote:isnt the sidepod new? huge bulge over the claro logo
http://img3.auto-motor-und-sport.de/Seb ... 884873.jpg
No it was introduced at spain, and rather than a bulge over the claro logo the area outside of that was reduced
F1NAC
172
If I am not mistaken, both cars had older version of RW flap
smhasan7
smhasan7
F1NAC wrote:If I am not mistaken, both cars had older version of RW flap
Yup that seems to be true... they didn't use the FW from Silverstone...
Amusingly, this thread had probably the least amount of posts for quite a while!
f300v10
f300v10
185
Both cars did race the latest spec front wing. The modified rear wing was probably never intended to race at Hungary, rather a data gathering exersize for Spa or another upcoming race with lower downforce requirements.
Kimi's car after the right camera mount had failed:
Seb post victory:
Curious thing this gurney on the inside end of the wing, never seen it used in this way, did the wing always have it, or is this something for Hungary?
f300v10
f300v10
185
The downward curve at the flap/endplate boundry is new for Ferrari (Merc has used it earlier this year at Canada), and was only tested in Hungary, not raced. I suspect Ferrari were testing it for an upcoming race, but perhaps it just didn't perform as well as the standard straight edged flap. I assume the goal of the change is to improve the L/D of the wing with some sacrifice in total downforce.
f300v10 wrote:The downward curve at the flap/endplate boundry is new for Ferrari (Merc has used it earlier this year at Canada), and was only tested in Hungary, not raced. I suspect Ferrari were testing it for an upcoming race, but perhaps it just didn't perform as well as the standard straight edged flap. I assume the goal of the change is to improve the L/D of the wing with some sacrifice in total downforce.
It definitely was raced, just look at the picture of Sebastian's car.
