2015 Russian Grand Prix - Sochi, October 09-11
Jonnycraig
Jonnycraig
Re: 2015 Russian Grand Prix - Sochi, October 09-11
Just_a_fan wrote:Cue half a dozen threads about how the cars must be redesigned because of this crash. :roll:
You can't design the car for every crash eventuality. You can change the barriers though - should be possible to do that to prevent submarining whilst keeping the barrier effective for other race series etc.
Maybe I'm missing the point, but Sainz has crashed at the fastest part of the track with very little speed scrubbed off at the point of impact, and been left completely uninjured. He literally could've and would've walked back to the garage if it weren't for the understandable abundance of caution by medics. The Tecpro has absorbed so much energy that a car impacting head on at 150+mph has 'only' partially breached the single skin metal barriers behind.
As seen with a very similar impact for De Jong at Spa, the Tecpro being lifted as it absorbs energy in neither track, nor car specific. Only needing to replace a small piece of barrier when a car hits head on at that speed and the driver completely fine is a best case outcome in all respects.
iotar__
F1NAC wrote:Jeeeeeeeeeeez such a boring session. Even Lewis was so bored that he parked the car. Temperatures dropping really quickly.
Why? It looked like a normal qualifying to me. Not liking results doesn't count.
Very anti-climatic...
Just like the whole season since numerous failures on the side of Rosberg with engines and other decisions.
- Ferrari - emperor's new clothes chapter 56, even Mercedes helping with engines wasn't enough, if you don't think they are the second quickest you'll see tomorrow, reasons: same as Spa
- On a track where it's difficult to overtake Lotus brains send a driver into traffic on a single run in Q3 3 minutes before the end, trademark trick
- What's the track/tyres logic again with Williams?
GPR-A duplicate2
64
GPR-A wrote:...... The pole sitter would be an easy meat on the "BENDER WAY" through a non existent first corner, offering great slip stream to the following car. Nico overdid it last year, but otherwise it would be good to start at P2.
I still hold on to this thought of mine. But looking at the FP3 and all of the Q3, Nico seems to have nailed a better setup.
I think the most important issue is that the Tecpro barrier could have hit Sainz his head or perhaps even worse: squeeze his head between the barrier and back of the cockpit. Don't get me wrong: I'm hugely glad that none of that happened, and that the barriers did their job actually.
So the point is that the crash exposed a very vulnerable point, which luckily did not mattered this time. It's not one thing contributing to this, but several: a low nose, rake, and the issue that breaking the suspension lowers the nose further, and probably a weakness to this kind of submarining in the shape of the tecpro barrier.
I agree with you but others are already pointing at the nose and wanting it changed...
Phil
66
isn't it more a problem of the barrier in place? I mean, these noses are meant to disintegrate up to the crash structures that then absorbs as much energy as it can. The barriers in turn need to absorb energy too, not lift like balloons and potentially get into striking distance of the head area. IMO this looks like an issue/failing of the barriers too in how it's absorbing the impact. Or they just weren't designed to absorb any impact to the lower part, helped by the fact that Sainz lost his left tire/suspension and the car was lowered even further. By moving the barrier upright, it looks to me that this has created a very dangerous situation where the barrier insufficiently absorbed and rather redirected into a collision path further up.
Personally, I think not having any fatal injuries for such a long time as eluded us into thinking how safe F1 and motorsport has become. Even Bianchi's unfortunate crash, has made us think "circumstance" - the high speed, double waved yellows and that hunk of metal in form of a tractor on track moving away another car that became a deadly obstacle. Truth is, motorsport, and especially F1 is dangerous, and no matter to what lengths you go to find adequate solution, you will never cover off every single possibility. It just ain't possible. Doesn't mean we shouldn't try, but as I said, I don't think the real issue here is the low nose. It's the way the barrier interacted with it.
#Team44 supporter
GPR-A duplicate2
64
GPR-A wrote:The compounds are the same as that were used in Singapore and should be interesting to see how they behave on Mercedes cars.
The answer is, Singapore was a fluke. The same tyres didn't caused any headaches in Sochi.
But the expectations of Mercedes' advantage slimming down due to these tyres also came down crashing. Still 8 tenths between Merc and Ferrari, despite Ferrari now having developed an ULTRA quali mode like what Mercedes have. May be the lower temperatures have something to do with Ferrari's performance going down and Williams' going up.
Felipe 92
-1
=D>
I agree with you, Lewis`s boredom is the only reason Nico is on the pole. I remember how bored Lewis was at 2007 Chinese GP when he parked his car in gravel trap. :lol: at your fanboyism.
Jonnycraig
Jonnycraig
As seen in the GP2 race now, the low nose of an F1 car is a red herring, as King's car threw the Tecpro upwards, as De Jong's did in Spa. It's not car or track specific, merely single seater specific.
AnthonyG
38
I allready wonder what will cause Rosberg's bad start tomorow.
Phil
66
Probably nerves. But given how dusty the track is (?), I think I see Rosberg getting a better start or both having a reasonably good start and possible collision, as Lewis will probably be used to Nico moving out of the way and Nico, having done so now a few times and after losing out this way in Suzuka, will be thinking enough is enough. Heck, this season could be a direct reverse of lasts year if there is any aftermath.
/half way kidding, I don't hope it, but neither would I be surprised if the initial part of my message turns out half true tomorrow.
#Team44 supporter
theblackangus
theblackangus
Jonnycraig wrote:
turbof1 wrote:
Jonnycraig wrote: Maybe I'm missing the point, but Sainz has crashed at the fastest part of the track with very little speed scrubbed off at the point of impact, and been left completely uninjured. He literally could've and would've walked back to the garage if it weren't for the understandable abundance of caution by medics. The Tecpro has absorbed so much energy that a car impacting head on at 150+mph has 'only' partially breached the single skin metal barriers behind.
Strangely enough this happened to me recently while go-karting. I was pushed out on a corner and the techpro barrier came up over the front of the kart and pinned my head against the roll loop, resulting in my head stopping the kart.
Here is a summary of the issue as I see it:
1. The barriers like techpro are designed to move with the vehicle to gradually show the vehicle (good)
2. To accomplish the above goal the barriers are only held down with their own weight
3. Attaching the techpro's down would cause additional safety issues as it would cause less movement and hence less deceleration room, additionally if they were held down whatever is holding them down could cause further risk to the driver
4. Making the techpros heavier would add additional risk of head trauma if the barrier impacts the driver helmet
5. They work great for closed cockpit vehicles as the risk of submarining is negligible.
I wish I had a solution to propose but I don't. The techpro barriers are very good at slowing deceleration of a vehicle, however they seem prone to submarining due to the nature of their design. Overcoming the above challenges are difficult to do w/o reducing the effectiveness of the barriers main goal of slowing the vehicle gradually.
As we saw with Carlos the barrier actually was lifted over his head by the shape of the barrier and the car.
lamn25
lamn25
Pole Lap Nico Rosberg https://youtu.be/B6P0GPNPnOs
F1NAC
170
=D>
lol, don't get me wrong but I was just joking around... :oops: what fanboyism?
Sainz will be allowed to race tomorrow: http://www.f1fanatic.co.uk/2015/10/10/s ... n-to-race/
