Toro Rosso STR11 Ferrari Speculation Thread
Juzh
161
Re: Toro Rosso STR11 Ferrari Speculation Thread
turbof1 wrote:It's possible that cooling has to be increased due increased output.
More output = more thermal efficiency = less heat = less cooling requirements ?
Well, the PU has quite a few different heat sources. The MGU-H unfortunaly only captures the heat from exhaust gasses passing through the turbo. There will be more thermal efficiency from there, but it still might be that the ICE requires more cooling, for instance.
Big Mangalhit
27
Maybe even high voltage cables and other electronic components as well. Also the packaging can create tougher heat spots that dissipate badly i guess. So maybe more efficient less cooling demands works better on paper.
Alcatraz
Alcatraz
There was a news that said that the livery should be lauched only on Feb 29th
cmF1
They've announced Casio as a team partner. Jumped ship from the parents because of Tag. At least it's kept in the family.
https://instagram.com/p/BB2ATlGq506/
プラスとマイナス
ferkan
ferkan
31
https://twitter.com/RoboCoPJ/status/701427773223604224 https://twitter.com/RoboCoPJ/status/701429137878208512 F1analisitecnica info. Basically says TR running pull rod suspension at front and there seem to be big issues with Ferraris PU reliability .
FrukostScones
162
haha, told them again incorrect cooling requirements?
no, I think planned sidepods/radiators for Renault PU were just too small.. for simple adaption... PU Fer 2015 last spec is not the general problem here...
Jano11
Jano11
ferkan wrote:https://twitter.com/RoboCoPJ/status/701427773223604224
Due to overheating.
ME4ME
79
How can there be PU reliability issues with 2015 proven unit :?
Jano11
Jano11
FrukostScones wrote:told them again incorrect cooling requirements?
Maybe the Renault engine wasn't as bad initially as someone teams made it look.
Jano11
Jano11
ME4ME wrote:How can there be PU reliability issues with 2015 proven unit :?
Not enough cooling?!
Looks like Renault might yet have a good laugh this season.
Steven
Owner
The car is out on track, so no more speculation needed.
Off we go to http://www.f1technical.net/forum/viewto ... 12&t=23857
