Sneaky!. Sauber did this trick a few years ago.FrukostScones wrote:http://img2.auto-motor-und-sport.de/Lew ... 928684.jpg
Holm86 wrote:Think its just like the old chimneys??FrukostScones wrote:http://img2.auto-motor-und-sport.de/Lew ... 928684.jpg
Like on this Sauber C30
http://motorsport.nextgen-auto.com/gall ... medium.jpg
Gridlock wrote:I can'y find the tweet now but Scarbs said they're just part of the crash structure, "no orifice".
I tweeted Scarbsturbof1 wrote:If it is the crash structure, which I very much suspect it is, you cannot open it. That crash structure is completely standarized, so no changes on it are allowed. If anything, either it's shadow or Mercedes painted it black.
RicME85 wrote:Deceiving picture is deceiving.RicME85 wrote:It looks like the end is uncapped, like they are venting out of it
https://twitter.com/ScarbsF1/status/701723826086871040
I'm not sure if it is. But it's possibly related to the intercooler they have inside the tub, or the batteries inside the tub.e30ernest wrote:Pardon me if this is a stupid notion, but if an opening is legal there, what if it's the reason for the unusually large air intake?ringo wrote:The crash structure may be the lump at the very top of the side pod opening. This lump may simply be a cooling outlet.turbof1 wrote:If it is the crash structure, which I very much suspect it is, you cannot open it. That crash structure is completely standarized, so no changes on it are allowed. If anything, either it's shadow or Mercedes painted it black.
The are it's located in doesn't have restrictions on openings in the bodywork IIRC.
Just an aside:ringo wrote:I'm not sure if it is. But it's possibly related to the intercooler they have inside the tub, or the batteries inside the tub.e30ernest wrote:Pardon me if this is a stupid notion, but if an opening is legal there, what if it's the reason for the unusually large air intake?ringo wrote:
Yes, they are standarized, but i think they are hollow and open on both sides.turbof1 wrote:If it is the crash structure, which I very much suspect it is, you cannot open it. That crash structure is completely standarized, so no changes on it are allowed. If anything, either it's shadow or Mercedes painted it black.
Based on this definition of rule 3.8.6:michl420 wrote:Yes, they are standarized, but i think they are hollow and open on both sides.turbof1 wrote:If it is the crash structure, which I very much suspect it is, you cannot open it. That crash structure is completely standarized, so no changes on it are allowed. If anything, either it's shadow or Mercedes painted it black.
But there is this rule:
3.8.6
The impact absorbing structures defined by Article 15.5.2 must be fully enclosed by bodywork, such that no part of the impact structure is in contact with the external air flow.
It's the same thing with or without a tube, the out facing structure parts still would be open as the tube would then be part of the crash structure. Also, I would assume that the impact structure is not allowed to have anything running through it. I'm eager to find out though, if they'd found something, holy malony I guess this is what Toto's been talking about.Longley wrote:Based on this definition of rule 3.8.6:michl420 wrote:Yes, they are standarized, but i think they are hollow and open on both sides.turbof1 wrote:If it is the crash structure, which I very much suspect it is, you cannot open it. That crash structure is completely standarized, so no changes on it are allowed. If anything, either it's shadow or Mercedes painted it black.
3.8.6
Would it be legal to put a thin tube inside the crash structure and connect the inner tube with the bodywork to fullfill rule 3.8.6?
Maybe to let some hot air out of the chassis or have some sort of extra air beneficial for the air flow to the diffuser...
(If the crash structure is hollow and open on both sides)
Or are there other restrictions that do not allow this idea?
Thx
