as i've already mentioned he had a fractured rib (maybe several) and a slightly collapsed lung (pneumothorax) ... he said that in the press conference
the lung has supposedly healed, the ribcage hasn't
Resolution as in the terms "resolved" or "better." There must be some lingering signs of bruising or swelling in the chest cavity or the organs. They most likely compared before/after scans etc.ChrisDanger wrote:What does it mean that there was "insufficient resolution of the signs"? It seems very vague, but that they can't see clearly enough, not necessarily that he's unfit to race. Surely there's a higher resolution scan they can do. What would they be looking for anyway, in his chest of all places?FIA via Matteo Bonciani wrote:Two sets of chest CT scans were compared and it was decided that there was insufficient resolution of the signs to allow him to compete on safety grounds.
I believe they're referring to the "signs" as "the signs that he shouldn't participate in the race" and the lack of proper resolution there.ChrisDanger wrote:What does it mean that there was "insufficient resolution of the signs"? It seems very vague, but that they can't see clearly enough, not necessarily that he's unfit to race. Surely there's a higher resolution scan they can do. What would they be looking for anyway, in his chest of all places?FIA via Matteo Bonciani wrote:Two sets of chest CT scans were compared and it was decided that there was insufficient resolution of the signs to allow him to compete on safety grounds.
"insufficient resolution of the signs" basically that is a convoluted way of saying that his ribs are not healed well enough to race.FuelTheJet wrote:I believe they're referring to the "signs" as "the signs that he shouldn't participate in the race" and the lack of proper resolution there.ChrisDanger wrote:What does it mean that there was "insufficient resolution of the signs"? It seems very vague, but that they can't see clearly enough, not necessarily that he's unfit to race. Surely there's a higher resolution scan they can do. What would they be looking for anyway, in his chest of all places?FIA via Matteo Bonciani wrote:Two sets of chest CT scans were compared and it was decided that there was insufficient resolution of the signs to allow him to compete on safety grounds.
It would be very odd if it was a literal 'resolution' issue.
From those 261kg you calculated one can easily take it with almost the arms only. The isometric(slightly eccentric) force a normal person can do with the arms on a steering wheel on an ideal (almost straight) position is easily way above 100kg, that will dramatically decrease the amount of force the seat bell will put on his chest. Plus the seat bell is well designed to spread that force across multiple areas to be safe in case of a several G deceleration (accident).Andres125sx wrote:I stand corrected, if the pressure to the pedal is 155kg and max deceleration is 5.2G, then the pressure on drivers chest is (80 * 5.2) -155 = 261kg
Like if three robust persons stand on your chest with you resting on the floor, and that with a broken rib and repeated constantly during three days and many hours... And Alonso was ready to take that!!
I think Merc will coldfoot Ferrari with softs. SS-S-S or SS-S-S-SSiotar__ wrote:They won't use mediums and neither will Ferrari. OK I'm not sure about thatPlatinumZealot wrote:Race should be over once mercedes slips on those meedz.
Edit: I forgot they made tyre decisions long time agoso there's no tyre testing and not much of tactics involved.
Hmm, so if they use mediums it's two stops SS - S - M with mediums lasting forever and earlier stop assuming Ferrari is behind and undercuts Merc with SS - S- S? Or Merc on the same strategy but with untested mediums?
This is a power circuit and puts a lot of energy into the tyres with loads of break energy going in. Last year, Mediums actually worked better than Softs. Also, Bottas on Mediums, managed to hold off Vettel on softs. I don't know if Merc or Ferrari would want to do SS-S-S, especially Ferrari, having chosen 3 sets of Mediums.FrukostScones wrote:I think Merc will coldfoot Ferrari with softs. SS-S-S or SS-S-S-SSiotar__ wrote:They won't use mediums and neither will Ferrari. OK I'm not sure about thatPlatinumZealot wrote:Race should be over once mercedes slips on those meedz.
- About bold text: fine, mediums might be better and it's good to have options but they will be used on only one stint and in emergency Merc can use them too. Reference point is two stops with SS and then S-M, or S-S or SS-M (?), scenario with short stint on S/SS and longer on mediums as an advantage already mentioned.This is a power circuit and puts a lot of energy into the tyres with loads of break energy going in. Last year, Mediums actually worked better than Softs. Also, Bottas on Mediums, managed to hold off Vettel on softs. I don't know if Merc or Ferrari would want to do SS-S-S, especially Ferrari, having chosen 3 sets of Mediums.
So last year was S-S-M for the Mercs and a lot differnet strategies already last year... SS-S-M won't work I assume so it makes the mediums not worth picking unless you go SS-M-M what Ferrari will try to do only to be butchered by softer tyred Merc.GPR-A wrote:This is a power circuit and puts a lot of energy into the tyres with loads of break energy going in. Last year, Mediums actually worked better than Softs. Also, Bottas on Mediums, managed to hold off Vettel on softs. I don't know if Merc or Ferrari would want to do SS-S-S, especially Ferrari, having chosen 3 sets of Mediums.FrukostScones wrote:I think Merc will coldfoot Ferrari with softs. SS-S-S or SS-S-S-SSiotar__ wrote: They won't use mediums and neither will Ferrari. OK I'm not sure about that
RZS10 wrote:This is probably slightly off topic but the german Sky commentators are so f*cking useless ...
"the opening in the airbox isn't just for the engine it is also for ... *awkward silence for 10 seconds, underside of another car is shown* ... oh look ... they are using duct tape"
"the hole at the axle is a tactical move by force india" .... tactical....
they were mocking the teams for not understanding the new quali format and had no clue what was happening themselves, they also confuse the drivers all the time ... and i thought the RTL guys were bad ... how can anyone who actually pays for Sky F1 find them acceptable? (i'm watching legally via shared skygo btw)
