It is not the hp. Honda ICE is between the MB and Ferrari in power but at that power setting,Honda would be 10kg of fuel short to finish the race.Also Honda can't make that power with full ER at the same time.PlatinumZealot wrote:You seem to be confused because at the end of the day the more power you can get out of every drop of fuel also means your engine's efficiency has increased.Sasha wrote:davidfroshanzen wrote: how much of the increase hp ?
Everybody gets confused with this engine formula.It's not the hp you can get,it's the energy you can get from the fuel.(the PU with the higher efficiency wins) So pretty much look at the modern marine diesel power plants for clues.Every % better means more power from the limited flow and capacity.
Canada updates for Honda is new fuel and mapping only.
