These pixs may be of interest:
2017 Michelin Challenge Design Winners 1 to 3
Finalists 3 to 20
Race car to win the Le Mans 24 Hours in the year 2030.
http://www.michelinchallengedesign.com/ ... -entrants/
Thanks for the link. will get the car finished off and send in the next day or 2.LVDH wrote:I will send you the link. On Linux there are no special requirements. If something does fail it will tell you what and you can install the missing package with a simple pip install missing-package.
The cars above are cool. Soon I will open a thread about a second challenge for more futuristic cars.
I can't wait too see it... but as a spectator. Futuristic cars are more funny to see than to design for me.LVDH wrote:The cars above are cool. Soon I will open a thread about a second challenge for more futuristic cars.
Thank you I would be glad to help.LVDH wrote:I will start a new thread soon. And I would welcome you to join the staff of that championship. Someone will have to create some CAD. And who would better?
Thank you Andre, I ´m using now fvSchemes and fvSolution from mwflow nad it looks like new simulation is quite matching official results. So I hope for next race my COP will be OK.LVDH wrote:I was very surprised by your results as well as it was not your style.
The issue with your car was that the forces were not very flat, so probably some transient effects are going on with your car. To keep results comparable I cannot just run your car transient, so I let it run twice as long as usual and the forces are reasonably flat. If your own simulations showed better behavior maybe car is very close to the edge and small differences in mesh setup cause very different results. If you like you can send me your own simulation assuming you are using OF and I will have a closer look into this.
Code: Select all
Setting up information for layer truncation ...
read tcp 192.168.99.1:51112->192.168.99.100:2376: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
C:\Program Files\Docker Toolbox>PAUSE
Press any key to continue . . .
