Ah, quite. I'd be surprised if they got to see things like cylinder pressures, or other internals they can't do much (or anything) about.Brian Coat wrote:Agreed. From my (very PU-centric) perspective, that's car data.
I believe PZ was referring to the full engine telemetry.
An aside - is there an actual value for "how close to knock you are", or perhaps "how big of a knock are we sensing"?
I don't know if there's an SI unit for it (I'd be surprised!).
It did occur to me that even things like ignition timing are probably driver controllable via the steering wheel (those streering wheel codes you hear like "Yellow G4" or whatever are probably both timing and fuelling).
Whether the drivers actually see the real figures from the engine chaps on what the various settings mean is more interesting.
I suppose you'd not tell anyone that unless there was a compelling reason to.
