McLaren MCL32 Honda
Jef Patat
Jef Patat
Re: McLaren MCL32 Honda
That's the old wing again.
f1rules
f1rules
605
f1rules
f1rules
605
They added a slit in the front part of the floor it seems, like others already did
https://pbs.twimg.com/media/C8xlGzuWAAA8VM-.jpg:large
f1rules
f1rules
605
Visible here also
matt21
86
via AMS
GoranF1
GoranF1
155
f1rules wrote:
07 Apr 2017, 05:54
Visible here also
http://www.f1fanatic.co.uk/wp-content/u ... _HiRes.jpg
Wasn't that already on the car during testing?
Jef Patat
Jef Patat
It's hardly visible in that pic, look at the other one, there's a slit about 5 cm from the floors edge, parallel to it for as long as the floor is visible.
f1rules
f1rules
605
No, they only introduced this weekend and i thinknonly on alonsos car
GoranF1 wrote:
07 Apr 2017, 12:16
f1rules wrote:
07 Apr 2017, 05:54
Visible here also
GoranF1
GoranF1
155
f1rules wrote:
07 Apr 2017, 12:29
GoranF1 wrote:
07 Apr 2017, 12:16
f1rules wrote:
07 Apr 2017, 05:54
Visible here also
It was on the car during testing.....but i think only 1 of those not 2.
GoranF1
GoranF1
155
f1rules
f1rules
605
Fabrega
Jef Patat
Jef Patat
I thought holes in the floor are not permitted but I'm not seeing a slit to the edge? Or is the metal part some trick?
ScrewCaptain27
577
Jef Patat wrote:
08 Apr 2017, 09:23
https://cdn-1.motorsport.com/images/mgl ... detail.jpg
Technically a "hole" should allow light to pass straight through. This doesn't, looks more like a channel open to the side.
- Serj Tankian
Jef Patat
Jef Patat
That's not a correct. Holes are defined in a different way, the word 'intersection' is used. That's why the holes in front of the rear tire are not realy holes, just the floor edge making some weird turns.
To my knowledge this was not the case in previous years. This is the rule for this year:
3.7.9.b
In an area lying 700mm or less from the car centre line, and from 450mm forward of the
rear face of the cockpit entry template to 350mm forward of the rear wheel centre line,
any intersection of any bodywork visible from beneath the car with a lateral or
longitudinal vertical plane should form one continuous line which is visible from
beneath the car.
And since the floor edge is 800mm from the centerline they can play with the last 10cm it seems. Strange no one else does this. It seems to enable some nifty sealing mechanisms.
