Yurasyk wrote: ↑16 May 2017, 21:42Yes I read. And I can say, they are wrong.tranquility2k4 wrote: ↑16 May 2017, 20:58Yes but did you actually read the analysis on espnf1. It's factual and it states he lost 2 sec due to VSC and 6 sec due to a Hams speed, which was insane at that point in the lap. Read all the points in bold in my previous post.Yurasyk wrote: ↑16 May 2017, 12:23
actually a wrong analysis
VSC ended directly on the end of the 36th lap for Lewis when he already entered on the pitlane.
Plots here
http://www.f1fanatic.co.uk/2017/05/14/2 ... ap-charts/
show that he lost on the entrance almost nothing to Vettel up to that moment. When on the next lap Vettel lose (relatively to other) more than 5 seconds just on the entrance before the finish line.
The gap Ham to Vet after the Ham pit is 24,4 s, the gap about a lap later just before the Vet pit is about 23s.
If VSC ended just after the Ham pit, he would gain some additional seconds and took the firm lead after the Vet pit.
Why they did not say directly that his out lap was 1.41.405 an the soft when Vet out lap was 1.43.275 on the medium.he delivered with truly awesome times in the middle sector (30.792s) and final sector (28.367)
1.9s is almost a normal difference between compounds + some loss on the first corner incident with Lewis. He simply could not win 6 seconds in this way. The actual gain was (as I said) 24.4-22.9=1.5s (between Ham out and Vet in) and about 2.0-2.5s over the whole Ham's out lap.
https://puu.sh/vS4qn.png
https://puu.sh/vS4z5.png
The rest 6 seconds were lose on the pit entrance under VSC.
Sorry but I think you're missing the point here. Comparing HAMs out lap with VET's out lap is irrelevant in explaining how HAM closed the gap to VET. VET's out lap was done after his pit stop when the gap had been closed, with HAM right behind him. It looks like VET also did a good outlap and yes you're correct MED was slower than soft but less so in race, maybe 0.5 - 1 sec, not so much 1.5 - 2 sec as in quali.
The comparison we need is the specific sectors on HAM's out lap vs VET's in lap. The fact of the matter is that HAM did a 30.7 and 28.3 on his out lap in S2/S3, which was so fast that they combined to be around 1.8 seconds faster than his fastest lap of 1.23.6 at the end of the race, even though he had half a tank of fuel at this time. I don't know VET's sector times on his in lap but considering he was on used softs that would be cold from running at VSC speed, then he would have lost a lot more than that. To put it into perspective VET lapped at a 1.25.5 the lap before the VSC came out, which is 2 SECs off HAM's fastest lap. Adding this to the further 1.8 sec we know his S2/S3 were faster then you have nearly 4 seconds. As already stated it's likely VET would lap even slower with cold tyres, so it's not inconceivable that 5 - 6 seconds were made up by the lap difference.
I'm not trying to make out Merc are better than Ferrari or Ham better than Vet I'm just saying I think a much bigger proportion of the 8 second gap was reduced by the pace difference on those respective out / in laps compared with the time lost in the pits due to VSC so it has been miscommunicated by the media. If you look at their pit stops Vet was actually 0.6 sec slower on lap 37 than Ham on lap 36 and Ham potantially had to enter pits slightly more slowly while VSC was still applicable, so this further accounts for a little time, i.e. Vet didn't have the best of stops. You could say the 8 seconds is made up of 5 sec for pace difference, 1 sec for poor stop and 2 sec for VSC which is probably ballpark correct.
The other point I tried to make earlier is with the sector times HAM did on that lap and a theoretical high 1m21s, e.g. 1m21.8 - with near half a tank of fuel, what is that as a fuel adjusted lap, is it even faster than pole? It must be close, which done in a race is really quite impressive, although track had rubbered in more.
