In theory, a greater a number of wing elements does mean you are able to run at higher AoA which does create more pressure drag and more lift.DiogoBrand wrote: ↑21 Oct 2017, 23:37I have a question for people that understand something about aero:
From my understanding, a milti-element wing is used so that you can keep the air more energized without separation, which allows more aggressive angles of attack. Also from what I understand, energizing air and larger angles of attack, which are often associated with multi element wings, create more drag.
So if you compare McLaren's wing to the top three teams, Mercedes, Ferrari and Red Bull have six-element wings, while McLaren has a 6 element wings with three slotted elements, which from my POV would behave somewhat like seven elements.
Long story short: Isn't McLaren's front wing draggier than the opposition's?
I understand that already, what I don't understand:Dipesh1995 wrote: ↑21 Oct 2017, 23:54In theory, a greater a number of wing elements does mean you are able to run at higher AoA which does create more pressure drag and more lift.DiogoBrand wrote: ↑21 Oct 2017, 23:37I have a question for people that understand something about aero:
However, having a larger number elements doesn’t automatically mean that the AoA of the wing has increased therefore the drag has not actually increased i.e if two wings were running at same AoA but one had more elements than the other, it’s not a given that the drag of the wing with more elements is greater.
1- no. if u have a variation of the same profile family and the profile is separated in more elements u should have (slightly ) less drag ( and less load ). the flux from the upper part of the first element raises the pressure on the lower part of the second element ( cause it s slower ) and not going on the top side of te second element it alleviates te pressure on it ( and so on ) therefore lowering the difference of pressure, the load but also preventing separation from too muc expansion on the lower part therefore lowering the wake dragDiogoBrand wrote: ↑22 Oct 2017, 00:07I understand that already, what I don't understand:Dipesh1995 wrote: ↑21 Oct 2017, 23:54In theory, a greater a number of wing elements does mean you are able to run at higher AoA which does create more pressure drag and more lift.DiogoBrand wrote: ↑21 Oct 2017, 23:37I have a question for people that understand something about aero:
1 - Given the same angle of attack, wouldn't a wing with more elements create more drag simply by how much it energizes the flow?
2 - Why run more elements without increasing AoA?
1. Its of my understanding that whilst you are correct that a wing of more elements does energise the boundary layer more frequently than a wing of lesser elements, this does not increase the drag. Assuming there is no flow separation, both wings will take the same amount of energy for a full pressure recovery to occur without separation of the boundary layer. It's just that the boundary layer of the wing with more elements has more energy due to its more frequent refreshment which is one of the reasons why it can run at a higher AoA.DiogoBrand wrote: ↑22 Oct 2017, 00:07I understand that already, what I don't understand:Dipesh1995 wrote: ↑21 Oct 2017, 23:54In theory, a greater a number of wing elements does mean you are able to run at higher AoA which does create more pressure drag and more lift.DiogoBrand wrote: ↑21 Oct 2017, 23:37I have a question for people that understand something about aero:
My theory: The multi element inner section is for strengthening y250 vortex which will seal the diffuser better increasing clean downforce generated from floor, this will allow to take some drag off the car from other elementsDipesh1995 wrote: ↑22 Oct 2017, 11:051. Its of my understanding that whilst you are correct that a wing of more elements does energise the boundary layer more frequently than a wing of lesser elements, this does not increase the drag. Assuming there is no flow separation, both wings will take the same amount of energy for a full pressure recovery to occur without separation of the boundary layer. It's just that the boundary layer of the wing with more elements has more energy due to its more frequent refreshment which is one of the reasons why it can run at a higher AoA.DiogoBrand wrote: ↑22 Oct 2017, 00:07I understand that already, what I don't understand:Dipesh1995 wrote: ↑21 Oct 2017, 23:54
In fact, you may see a reduction in drag. Assuming again there is no flow separation on either of the wings, one reason for the reduction in drag is that the flow will be laminar for a greater portion of the wing. This is due to the fresh boundary layer effect caused by the slot gaps. This allows for a thinner laminar boundary layer compared to a lesser element wing which would have a thicker boundary layer (very likely to be turbulent as well but this depends on the location of each slot gap and transition parameters i.e if we are considering the leading edge region of a wing, the flow would be laminar for both cases, the boundary layer however would be thicker for the wing of lesser elements). Therefore, this reduces the skin friction drag.
There are probably more reasons than this that I can't think of atm
2. Increasing AoA isn't the only reason to run more elements. In the case of the new McLaren wing, the increased number of slots at the inboard section strengthens the Y250 vortex whilst the increased number of slots at the footplate strengthens the edge vortex all whilst keeping the AoA the same as the previous wing.
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
considering how the pressure difference would be reduced because of the slots I would say it actually weakens the vortex. This is all about aero sensitivity imoBloodLad91 wrote: ↑22 Oct 2017, 19:11My theory: The multi element inner section is for strengthening y250 vortex which will seal the diffuser better increasing clean downforce generated from floor, this will allow to take some drag off the car from other elements
The slots are squeezing air at the divided bottom elements creating higher pressure and there is lower pressure behind top wing elements where airflow will accelerate strengthening y250 vortexwesley123 wrote: ↑23 Oct 2017, 10:00considering how the pressure difference would be reduced because of the slots I would say it actually weakens the vortex. This is all about aero sensitivity imoBloodLad91 wrote: ↑22 Oct 2017, 19:11My theory: The multi element inner section is for strengthening y250 vortex which will seal the diffuser better increasing clean downforce generated from floor, this will allow to take some drag off the car from other elements
we are comparing it with a standard non slotted solutionBloodLad91 wrote: ↑23 Oct 2017, 14:09The slots are squeezing air at the divided bottom elements creating higher pressure and there is lower pressure behind top wing elements where airflow will accelerate strengthening y250 vortexwesley123 wrote: ↑23 Oct 2017, 10:00considering how the pressure difference would be reduced because of the slots I would say it actually weakens the vortex. This is all about aero sensitivity imoBloodLad91 wrote: ↑22 Oct 2017, 19:11My theory: The multi element inner section is for strengthening y250 vortex which will seal the diffuser better increasing clean downforce generated from floor, this will allow to take some drag off the car from other elements
Injecting air from top to bottom would reduce the pressure difference, and a vortex is largely based on this pressure difference. Thus, more slots=weaker vortex. It's main advantage here, and this is why Ferrari and Mercedes have a small upward shape here, is that it will allow the vortex to properly exist as air will be injected as it's effectiveness will change as the pitch changes. This is why front wings have 6 elements nowadays.BloodLad91 wrote: ↑23 Oct 2017, 14:09The slots are squeezing air at the divided bottom elements creating higher pressure and there is lower pressure behind top wing elements where airflow will accelerate strengthening y250 vortexwesley123 wrote: ↑23 Oct 2017, 10:00considering how the pressure difference would be reduced because of the slots I would say it actually weakens the vortex. This is all about aero sensitivity imoBloodLad91 wrote: ↑22 Oct 2017, 19:11My theory: The multi element inner section is for strengthening y250 vortex which will seal the diffuser better increasing clean downforce generated from floor, this will allow to take some drag off the car from other elements
