godlameroso wrote: ↑12 Nov 2017, 03:02
Are you serious? You can't compare the pace of the leaders in clean air to Alonso stuck behind a car that's a second a lap slower, Alonso started from the back in Japan, he started from the back in Mexico, his pace was good in COTA, if you look at his long run he's doing 13.75 ish, slightly faster than the Force India, Williams, and Renault, and the leaders were doing mid to low 13's.
Almost every time we see the long runs in FP2 show more or less where the pace of the cars are, look how far Hamilton finished behind Verstappen, I recall he was lapped in Mexico, that's how much you get held up behind slower cars. There's a huge difference when you're running in clean air and can push the car, vs when you're stuck behind a slower car, furthermore, Brazil is almost as difficult to pass at as Mexico, maybe even more so. Relatively thin air reduces the effectiveness of a slipstream, and difficulty to follow in sector 2 makes mounting a serious challenge through S3 & 1 tricky even with the Honda PU.
The pace is there.
What, firstly yes you can, second, in clean air at no time has he had the pace of the leaders, at any stage this season, just hasn't happened. Second, one of the reasons he gets stuck behind cars that are much slower is... he's nearer their pace. That car in clean air as well as not, finishes in general 80+ seconds back from the leaders, that hasn't changed. If in three races they finish in clean air 80 seconds back then they finish 85 seconds back having been 'held up' by another car for half the race, do you really think they'd magically be 40 seconds down the road without the traffic?
As for the times you mentioned, without context they are meaningless. Practice times do not at all directly translate to race pace without knowing roughly what is going on in terms of the program being run which has a HUGE effect on the pace. All last year and most of this year Ferrari beat Merc very often in FP2 yet were half a second back compared to Mercedes race pace, because they aren't directly comparable. When you know the team's program you can estimate but requires more than basic reading of the times. Perez did 4 hot laps on his supersofts, Alonso did 2, that directly makes their stints not comparable
https://pbs.twimg.com/media/DOScOmTX0AM5e3f.jpg
Combine that data for tires, sometimes you have to get a little creative also, Vettel pitted so many times that two pitstops are missing, judging by the times and laps done, the final two pitstops and as such the final 6 laps were actually on the less used soft tire. However, Vettel ran fully 32 laps on that tire while averaging a lower lap time than Alonso who did 20, again pretty much incomparable here. You run the tires to a temp you want to achieve a distance you want, Alonso did the least heavy running on the tire so times should be faster.
Then factor in other things, Honda doesn't care about engines being used, they want the engines to run higher modes more often to get data. FI are budget constrained and are desperate to not take engine penalties(because beyond 4 engines they pay more for every engine), so chances are FI are in lower engine modes, Ferrari don't want penalties not due to budget but branding, they don't want another failure compared to Mercedes.
On fuel, Mercedes have for a very very long time run absolutely max fuel, Mclaren from memory seem to never seem as competitive as FP2 suggests so I would guess they are on midrange fuel, FI's entire strategy is really about running as long as possible and tire saving, one stopping when others might two stop so again longer run with heavy fuel is more relevant to them as their first stint is crucial to their style of racing but I can't say for sure they run heavy fuel. Ferrari tend to run midlevel fuel but also looked well off the pace on Friday and improved a lot so personally I think while their times are already better, they gained significantly since then.
They certainly don't seem to have terrible pace, a shorter track with only two real straights helps but I think Alonso will finish 70+ seconds off the leaders even if he runs most of the race in clean air because their car is that much slower, it's that simple. Hamilton (without crashes, damage, badly timed safety cars) shouldn't have any trouble catching and passing him.
