Lower drag is virtually no benefit for a high speed corner unless it's taken flat out, because the car needs to be slowed enough to take the corner regardless of whether it's due to drag or lifting. The reduced drag will help when back on full throttle though.godlameroso wrote: ↑19 Feb 2018, 16:39I would think that following cars are mostly affected in medium speed corners. And that for high speed corners 260kph+ the loss of drag negates any lost downforce from following, to a point. Not to mention at these speeds most cars are making excessive downforce and could shed some. For example 130r in Suzuka, and last year we saw cars following through most high speed corners in Silverstone.
Right! and as downforce increases there will be more easy flat corners and more places to make up time with slip stream. Vettel stayed with Hamilton all race because of the slip stream in Spa. At the same time all the mid speed corners in sector 2 kept him at bay. Its why Hamilton couldn't pass Raikkonen in Brazil, too many mid speed corners. Or a chicane at the end of the straight.Brenton wrote: ↑20 Feb 2018, 01:27Lower drag is virtually no benefit for a high speed corner unless it's taken flat out, because the car needs to be slowed enough to take the corner regardless of whether it's due to drag or lifting. The reduced drag will help when back on full throttle though.godlameroso wrote: ↑19 Feb 2018, 16:39I would think that following cars are mostly affected in medium speed corners. And that for high speed corners 260kph+ the loss of drag negates any lost downforce from following, to a point. Not to mention at these speeds most cars are making excessive downforce and could shed some. For example 130r in Suzuka, and last year we saw cars following through most high speed corners in Silverstone.
Downforce increases exponentially with speed, so the dirty air penalty similarly gets worse with speed.
Of course 130r doesn't have a dirty air penalty... It's taken flat out so it's effectively a continuation of a straightaway in technical terms.
There just aren't many high speed corners in F1 anymore that aren't flat out. The improved grip with speed due to the incredible downforce these cars have means that there's only a narrow window of corner types (radius+ other details) that fit the "high speed but not flat out" criteria.
That one's mainly because the exit onto back straight is already at 200+ and the leading car has less net gain by being on the throttle 0.5s earlier. The overtake can then continue all the way into the next lap if the car ahead had to defend on the back straight.godlameroso wrote: ↑19 Feb 2018, 16:39Silverstone hard to follow but cars can still race for some reason.
One of the things we’ve started, and we’re now six to nine months into it, is a programme to understand how we can enable these cars to race each other more effectively.
We need to keep the aerodynamic performance at a high level, but we need to do it in a way that’s more benign and more friendly to the cars around it.
There’s almost a force field that exists at the moment, a bubble around each car. And the car attacking it can’t get near it, because as soon as it gets within 1.5-2.0s of the car in front, it loses so much performance. It can’t get near.
So we started the programme, and I’m really excited by what I’m seeing.
I'd say not until they announce their plans, looks like ahead of Bahrain they'll tell teams.Vanja #66 wrote: ↑31 Mar 2018, 18:55Should we start with 2021 aero package regulations thread? Brawn's team is on it for more than 6 months already.
https://www.motorsport.com/f1/news/braw ... 20664/?s=1
I don't know what they're suggesting - as they've not told anyone - but the rumour I heard was they wanted to remove the FWUF (front wing upper flap - the cascade of flaps near the endplate) and turning vanes, but not necessarily reducing the number of elements on the wing. The implication seems to be when in the wake the complex flows they create to divert the front tyre wakes is disturbed, and when that loses efficacy the floor of the car suffers. I don't think they want to reduce the span to inside the wheels, a wider front wing is better aerodynamically for the front wheels and front end of the car.f1316 wrote: ↑08 Apr 2018, 11:11I’m not sure I buy this idea about simplifying - and I believe part of the suggestion was also downsizing - the front wing in order to aid overtaking. To me that sounds a lot like what we had pre 2009 which is what led to all the messing about with the rules to begin with (yes, they were also raised FWs, which I never understood, so perhaps that also exacerbated the problem).
It seems to me that you have plenty of tracks where overtaking is perfectly easy enough - look at how the lead two cars, with supposedly the smallest delta, could pass for the win in Spain (yes, different tyres, but strategy is part of it) Malaysia and Austin, not to mention all the overtaking we saw in places like Brazil (again, coming from the back is part of the equation - you’re never going to have any overtaking unless a faster car is behind a slower car - it’s just impossible).
So it seems to me the issue is less about the cars and more about the circuits; my view is that some football matches are 0-0, some boxing matches go to points decisions with hardly a punch thrown, some basketball games are a runaway victory by the 3rd quarter - I.e. not all races are going to be a ‘superbowl’ (although, that said, plenty if superbowls suck too). It’s inherent to all those sports and it’s inherent to F1 that some races are going to be dull and/or have other areas of interest aside from overtaking (e.g. seeing the cars brush the barriers at Monaco).
But if you do insist on making overtaking easier everywhere it’s track-specific - so the effort should go into fixing the tracks you want to keep and replacing others with better overtaking tracks (let’s say Russia could be replaced by,for the sake of argument, Indy - imagine DRS kicking in at the end of the banking).
So would it be better if the last turn in Sochi was slower or faster? This is a very good point and deserves consideration, what about at the end of the straight, would making that corner faster or slower promote overtaking? Is the set up for the turn after the long left better? A small change at all of these places can make a huge difference. Just small changes to the camber on that turn leading to the straight can make a huge difference. Like a favorable camber offline, with no camber change through the ideal line, while making the corner slightly faster and wider.Juzh wrote: ↑23 Feb 2018, 16:18That one's mainly because the exit onto back straight is already at 200+ and the leading car has less net gain by being on the throttle 0.5s earlier. The overtake can then continue all the way into the next lap if the car ahead had to defend on the back straight.godlameroso wrote: ↑19 Feb 2018, 16:39Silverstone hard to follow but cars can still race for some reason.
If you're 0.5s earlier on the throttle coming out of a slow corner (say 100-150 kph) you gain so much ground with the acceleartion of an F1 car you're effectively out of slipstream danger in those few tenths. Last turn in Sochi a very good example. 1.2 km long flat out section but next to no overtaking.
