Sieper wrote: ↑27 Feb 2018, 01:21
Yes I do, but there is something sticking up and between the two arms of the split wishbone, it has a Jagged, torn edge, brown colered specs where it has torn. A cm or two back also something White is torn where it seems the Outer layer of material has ripped off.
...and the perfectly clean, straight line of the wishbone besides it shows you it's not the wishbone, but more likely just the gearbox housing you're seeing or cover with a bit of gravel rash.
The fact there's a wheel on it should give you a clue too. You're having posts deleted because this belongs in the testing thread, not here.
