Aston Martin Red Bull Racing TAG Heuer RB14
tmoneyr007
tmoneyr007
Re: Aston Martin Red Bull Racing TAG Heuer RB14
Another run by Max without the "Z" wing? Connecting the sidepod to the floor?
Sieper
73
Good catch, so I think they wanted confirmation from both drivers that sacrificing the drag for the improved grip is the way to go. And to see If possibly they could extract performance even without the flow conditioner.
roon
roon
412
More of those anhedral radiators. You can also see they are blocked off partially due to the cold weather.
gandharva
252
The sidepod winglets are slitted. We have seen this last year too.
Shakeman
33
the EDGE wrote:
27 Feb 2018, 22:01
I think the difference with the Red bull chassis is that even down on power & released with compromised aero... it was still the 3rd quickest car
There you go making excuses for a team with one of the biggest budgets in F1...
TwanV
TwanV
Sieper wrote:
27 Feb 2018, 23:13
Not sure this is primarily about drag since any additional added downforce at the rear could decrease the drag generated by the rear wing, which is normally the biggest contributor. My bet is that it modifies the high/low speed balance difference.
Sieper
73
Yes indeed, that would seem more likely (I was just thinking about the drag the thing itself costs versus the benefit on the flow downstream but yes, your description is more accurate, better when I think about it) in any case, quite a crude testing method :).
gandharva
252
Day 2:
Day 3: 2017 frontwing concept
There's a far simpler, more normal explanation for the on/off runs with the vertical turning vanes - they're not working properly, and they're running correlation tests to see why.
Autosport:
Testing is all about trying things and yesterday Red Bull experimented with what we call the vertical turning vane, which picks up the turbulent wake off the back of the front tyre. It’s obviously not getting the results expected, so Red Bull took it on and off and then today experimented with it off again.
It lets us see more detail on the leading edge of the sidepod and how the bargeboards pull airflow out from underneath the front of the chassis and onto this leading edge section.
Red Bull’s sidepod concept is quite different from others in that it’s the minimum possible size needed to house the cooling requirements within it - it really is a limpet style. The turbulent airflow coming off the rear of the tyre will affect it differently than on other cars, so this is could be why Red Bull is doing some experiments in this area.
Gary Anderson
Sieper
73
could indeed be that they are not working (as hoped for). Apparently they have one version then available only.
astracrazy
astracrazy
31
I'm guessing they must have already been unsure about this part before they turned up to the test? Its unlikely track side they pinpointed a potential aero problem with a part like that.
I would guess we will see a new design there for the second test because its not better to not have one.
nevill3
16
Or it could just be the mountings were not strong enough and they were working loose, so they ran without them whilst attempting to fix/modify them. Tried them again but the solution did not work so they had to come off again.Meanwhile some running with them off is better than sitting in the garage.
ScrewCaptain27
577
Via AMuS:
- Serj Tankian
Mr.G
34
gandharva wrote:
28 Feb 2018, 10:49
http://abload.de/img/13tsci.jpg
No, that's from suspension... Look on the left one, than back to the right...
