Scuderia Ferrari SF71H
Maritimer
Maritimer
19
Re: Scuderia Ferrari SF71H
roon wrote:
04 Apr 2018, 22:54
McLaren-esque pylons. New?
No, been there since testing
An impression of the front wing dissasembled:
f300v10
f300v10
185
The central section boat tail has gone back to having a more well defined angular channel, similar to last year but not as pronounced. Gone is the flatter, more rounded solution from late 2017, and all of 2018 to date. They have also included the winglet on the outer edge, first seen in FP1 in Melbourne.
The new profile reduces the AOA of the central section, likely improving the stability of the flow, with a slight reduction in total expansion. I assume they are trading a small amount of total downforce for more consistent/stable downforce by keeping the central flow attached over a broader working range.
Hopefully this will increase the drivers confidence in the car and allow Seb to push harder.
That's pretty much it, mate. :) There are so many thing influencing diffuser, it's crazy. I remember seeing the radical diffuser on SF70-H in Hungary (?) and was thinking - that's a very big step, not sure if they can pull it off. Lot's of small thing need to be working perfectly all over the car to make a decent amount of downforce without excessive separation in diffuser.
ferkan
ferkan
31
It does appear as if Ferrari actually used this diffuser in Melbourne so not new.
f300v10
f300v10
185
ferkan wrote:
05 Apr 2018, 16:40
Do you have any evidence of that, like a photo? I keep a close eye out for changes to the diffusor and I'm pretty sure this is new.
Monster Hesh
Monster Hesh
turbof1 wrote:
05 Apr 2018, 12:31
http://u.cubeupload.com/turbof1/colourdissasembled.png
That needs to be a lego set!
f300v10
f300v10
185
Here is a better view via AMUS, clearly showing an updated profile in the center section
Nice bargeboard closeup as well.
ScrewCaptain27
577
Extreme close-up of the bargeboards:
Another diffuser close-up:
Via AMuS
- Serj Tankian
nemanja
nemanja
ferkan wrote:
05 Apr 2018, 16:40
It didn't. It was just tested for a short period of time during one of the FP.
f300v10
f300v10
185
nemanja wrote:
05 Apr 2018, 17:05
ferkan wrote:
05 Apr 2018, 16:40
The outer edge winglet was tested in FP1. The update to the central tunnel section was not, and is new.
nemanja
nemanja
f300v10 wrote:
05 Apr 2018, 17:07
nemanja wrote:
05 Apr 2018, 17:05
ferkan wrote:
05 Apr 2018, 16:40
Correct.
JPBD1990
JPBD1990
49
nemanja wrote:
05 Apr 2018, 17:11
f300v10 wrote:
05 Apr 2018, 17:07
nemanja wrote:
05 Apr 2018, 17:05
Correct.
I’m not asking this as to dispute it, only out of interest... is there somewhere (or can you or someone kindly create) a comparison image? I’m really hoping these changes combined with the rumoured floor in China reap some benefit
nemanja
nemanja
JPBD1990 wrote:
05 Apr 2018, 17:20
nemanja wrote:
05 Apr 2018, 17:11
f300v10 wrote:
05 Apr 2018, 17:07
Correct.
At the top of this page you have a picture from Barcelona, Melbourne and now.
