How big is this front K you propose and where is it (or are they) situated?MrPotatoHead wrote: ↑24 Apr 2018, 00:11
The same way they do in LMP - by using the front axle as well as the rear axle to harvest.
The Porsche 919 has a 300KW KERS motor on the front axle.AJI wrote: ↑24 Apr 2018, 00:14How big is this front K you propose and where is it (or are they) situated?MrPotatoHead wrote: ↑24 Apr 2018, 00:11
Sure, but where do you put that on an F1 car? The only way I can see it working is if there are 2 small K's mounted outboard of the monocoque.MrPotatoHead wrote: ↑24 Apr 2018, 00:29The Porsche 919 has a 300KW KERS motor on the front axle.AJI wrote: ↑24 Apr 2018, 00:14How big is this front K you propose and where is it (or are they) situated?MrPotatoHead wrote: ↑24 Apr 2018, 00:11
Under the drivers feet with a tiny diff?
Just like that.
That's pretty much what I was thinking. I'm not quite as talented as drawing as you though. All my sketches look like the Homer car...
The Audi one shown above looks like it would fit. The problem is what to do with the suspension - where do the torsion bars go, for example.
