Scuderia Ferrari SF71H
Mr.G
34
Re: Scuderia Ferrari SF71H
timbo wrote:
11 May 2018, 21:22
MtthsMlw wrote:
11 May 2018, 21:20
So, is the RW new too since it's painted with flo-viz?
Maybe, but they also could test the effects of the changes on the car downstream, or simply verify the data from the wind tunnel on the different track.
or impact of the new mirrors holders.
Longer and reshaped vertical slots in RW endplate.
Both pictures via AMuS
roon
roon
412
Is it ok to mention that the team who advocated the halo, also has the most developed halo aero solutions, and perhaps a sidepod design built around the device?
It's like Merc sitting in engine talks pre-2014, helping with the wording around DI and electric turbocompounding. 8)
holeindalip
holeindalip
roon wrote:
12 May 2018, 00:01
I'm pretty sure the halo was a Mercedes design though
paddyf1
paddyf1
holeindalip wrote:
12 May 2018, 02:25
roon wrote:
12 May 2018, 00:01
I think it was mercedes who came up with the halo, ferrari and red bull came up with the aero screen....i think.
LM10
LM10
121
Isn't this a new chassis? Looks less tight.
JPBD1990
JPBD1990
49
LM10 wrote:
12 May 2018, 09:25
You’re right, the rear opening on the engine cover is definitely sitting higher... could just be a cooling requirement here as it’s much warmer than Baku was
Diffuser is going towards even more aggressive sideways expansion, instead of upward (like classic designs usually do). This is visible with more taper on narrower central section, as well as on outboard trailing edges. Flaps around diffuser trailing edge getting even bigger as well, to enhance this effect even more. It's not surprising to see this development direction on these cars, allowed diffuser height is clearly not enough for their potential.
F1NAC
170
According to AMUS, their rear wing mirror from Monaco onwards will be deemed illegal
[media]https://twitter.com/tgruener/status/995246208976334849[/media]
Rob51
Rob51
F1NAC wrote:
12 May 2018, 12:17
thought FIA had given the "green light" for teams do put mirrors on the halo?
AF Corse #51 #71
aral
aral
26
Yes, the halo mounted mirror and its wing are totally legal, but as ferrari were quicker off the mark than others, the other teams managed to get it banned. Jealousy knows no bounds!
