Scuderia Ferrari SF71H
roon
roon
412
Re: Scuderia Ferrari SF71H
siskue2005 wrote:
13 Sep 2018, 16:13
Better picture
Notice that it does not immediately obstruct the camera, there is a hole cut out in the housing. Other teams use similar devices.
Morteza wrote:
13 Sep 2018, 15:46
This cooler is also new
Via AMuS
Both examples would block line-of-sight between camera and steering wheel.
M840TR
M840TR
315
Tea-tray extension. Note similar guide vanes to direct air under the bargeboards.
Floor.
Rear suspension.
roon
roon
412
SF71H bodywork relatively simple compared to the rest of the field *except* for the edges of the floor, where they have surpassed McLaren, even.
ScrewCaptain27
577
Some flow-viz pics from Racecar Engineering:
- Serj Tankian
Dipesh1995
Dipesh1995
104
Bit of trailing-edge region flow separation showing the rw flap is running at/very close to its limit in terms of usable AoA.
roon
roon
412
Looks like a near vertical vortex forms inside the endplate, sprouting from the first main louvre.
M840TR
M840TR
315
roon wrote:
19 Sep 2018, 02:03
https://pbs.twimg.com/media/DnC4CI0X4AA9rMs.jpg:large
https://i.imgur.com/I3NELfp.jpg
Vortexes form at the tip of a surface though. This highlighted area just indicates laminar upwash.
M840TR
M840TR
315
dfegan358
dfegan358
-2
Any updates planned for Russia?
Mercedes made a big step in Singapore. Ferrari need to respond!
timbo
timbo
111
dfegan358 wrote:
21 Sep 2018, 01:21
Any updates they present in Russia are a product of weeks (if not months) of research and manufacture. It is impossible to "respond" with updates.
F1NAC
169
HALO disassembled
AMuS
roon
roon
412
MtthsMlw wrote:
26 Sep 2018, 20:13
AMuS
I bet those fins work pretty well. Considering they would fill pretty much all of the small gap between the brake shroud drums and the wheel, and spin upwards of 3k RPM. I'm still curious as to whether ambient temperature air or heated brake disc exhaust flows through this small gap. Brake drum/cake tin designs seem to vary quite a lot, and sometimes it looks like ambient air is being ducted in, and other times it looks like brake disc exhaust is being vented there. Usually people say they're trying to heat the wheels in order to heat the tires, others say they're trying to cool the tires by cooling the wheels.
M840TR wrote:
19 Sep 2018, 12:20
zibby43
zibby43
613
