carisi2k wrote: ↑13 Feb 2019, 23:53
TwanV wrote: ↑13 Feb 2019, 16:38
BrunoH wrote: ↑13 Feb 2019, 16:34
this looks really agressive, i hope they didnt take hondas data as assured that they can run this little cooling/ venting.. if its ok its a massive step forward from Honda, the smallest, lightest , and lowest COG, PU in the grid. Mclaren must me going nuts...
Curious about the engine, not a Honda expert. what makes you say it has the lowest CoG? I would also say the engine cover actually looks taller than the Merc..
high engine cover is due to radiators installed above the engine and not the engine itself.
That! That`s the reason they have so small sidepods air intakes! And that leads obviously to a higher CoG of the car not the engine, which is far worse, btw ...
And that`s not the weakest point in Honda`s PU armour. Maybe this year they reached almost the same max. power output both in the race and in qualy but certainly they are behind Ferrari and Merc in combustion efficiency hence requires more fuel than both ICE`s above mentioned.
With 2 tenths per lap gain for every 5kg of fuel - as Andy Cowell said - this means Merc acknowledged that the gain Ferrari`s ICE was doing last year was mainly due to a better fuel combustion process (coming out from an exclusive technology provided by Mahle and a renowned scientist, had I`m not wrong) and acted this year accordingly ...
