Renault F1 R.S. 19
roon
roon
412
Re: Renault F1 R.S. 19
RZS10 wrote:
19 Feb 2019, 15:57
The DRS opened further than it should have ... the center part went higher than the outside
And this is why Ferrari added a swan's neck to their flap this year. RW flap is wider than ever.
DiogoBrand
73
roon wrote:
20 Feb 2019, 00:25
RZS10 wrote:
19 Feb 2019, 15:57
https://i.imgur.com/o7HezwD.png
https://i.imgur.com/ZQd1k0n.jpg
Not only wider, but I think the chord has increased as well.
The thing I dont get is how the flap bent upwards. Either the high pressure above the lower element pushed it up, or the upper element was raised so high that it generated lift.
The mini Bb and stuff behind the bb
djos
113
Blackout wrote:
20 Feb 2019, 06:19
https://i87.servimg.com/u/f87/14/79/55/26/c0b3-910.jpg
Wow, no shortage of development there! =D>
"In downforce we trust"
hollus
dren wrote:
19 Feb 2019, 13:42
FMP wrote:
19 Feb 2019, 12:44
SiLo wrote:
19 Feb 2019, 12:21
I have a feeling that end plate design will be copied by a lot of teams. Looks like its essentially adding small wings underneath which will help keep airflow attached under the wing.
Not only that, creating an upwash behind the car also will make the diffuser generate more downforce. Anyone have any clear negatives regarding airflow from this endplate solution?
Some of the other teams are moving air outwards, which also helps with the expansion at the back. The diffusers aren't only expanding air upwards, but outwards, too.
Yup. Those gills are not only pushing the air upwards, which should help the wing and create downforce on its own, but actually, to quite some extent, inwards, which conspires to fill the low pressure area under the wing. They also should create a lot of drag by themselves, but by the same filling-in of the low pressure area behind the wing, they should reduce wing drag.
As usual, it is a compromise.
Rivals, not enemies.
ScrewCaptain27
577
AMuS
- Serj Tankian
Coefficient
Coefficient
DiogoBrand wrote:
20 Feb 2019, 05:10
roon wrote:
20 Feb 2019, 00:25
RZS10 wrote:
19 Feb 2019, 15:57
The actuator must have opened the flap to a beyond aero-centre position causing it to distort. I think they probably can resolve this by recalibrating the actuator.
Jambier
Coefficient wrote:
20 Feb 2019, 15:52
DiogoBrand wrote:
20 Feb 2019, 05:10
roon wrote:
20 Feb 2019, 00:25
I hope they can fix this quickly
This morning they weren't using DRS at all.
This afternoon they use 2018 DRS (less opening) according to F1 TV
So since D1 of testing, no real 2019 DRS usage
CLKGTR
CLKGTR
100
Interesting floviz pattern on the front wing endplate
Godius
186
What is the purpose of the miniature pipe right beneath the exhaust pipe and in between the wastegate pipes? Maybe it is not a pipe but it is rather difficult to see what it really is.
ScrewCaptain27
577
Godius wrote:
22 Feb 2019, 01:17
That should be the oil breather.
- Serj Tankian
_cerber1
261
There is information about the reason for stopping yesterday on the tests?
NathanOlder
I too would like to know why Hulkenberg stopped yesterday during the test.
GoLandoGo
Lewis v2.0
King George has arrived.
