Red Bull RB15
Re: Red Bull RB15
Godius wrote:
20 Feb 2019, 12:46
Seems like this is the new higher downforce rear wing AMuS is talking about. The RW main plate looks bigger indeed but I would like to see more pictures of it:
AMuS wrote:Wir hören aus dem Red Bull-Lager: Ab heute schmückt der richtige Heckflügel den RB15. "Vorher war es ein Montreal-Flügel", scherzt Teamchef Christian Horner. Soll heißen: Ein Heckflügel mit zu wenig Anpressdruck. Der neue erzeugt mehr Abtrieb im Heck. Das erleichtert es den Ingenieuren, das Auto auszubalancieren. Honda hat zur Sicherheit den Motor getauscht nach dem Einschlag von Pierre Gasly gestern. Untersuchungen haben ergeben, dass der Motor aber nicht beschädigt wurde.
I don't know if this is the new rear wing, but here's another photo of it
DAMNINice
37
Re: Red Bull RB15
Rear wing endplates are more simplistic.
REal men play with twins!
dren
227
Re: Red Bull RB15
DAMNINice wrote:
20 Feb 2019, 13:31
They were like that on the launch car. It doesn't look new to me.
Honda!
nevill3
16
Re: Red Bull RB15
Horner has been quoted as saying that they have been running a "Montreal Spec" wing up until now and the car was not easy to balance but the new wing should solve this
Re: Red Bull RB15
Two different rear wings tested by RB
Via @AlbertFabrega
dren
227
Re: Red Bull RB15
Yes, much larger second element on the new wing. Thanks Morteza
Honda!
Re: Red Bull RB15
The main element is more highly cambered on the "big wing". Look at the difference in the apparent length of the central pylon.
TwanV
TwanV
Re: Red Bull RB15
Just_a_fan wrote:
20 Feb 2019, 14:18
EDIT Yeah, sitting much lower this one. I was thinking the support structure was thicker too but on closer inspection I think this due to the camera angle. the DRS-y bit is more upright too.
Re: Red Bull RB15
Better photos
Bill
Bill
Re: Red Bull RB15
Why do people keep talking about so called "radical " front wing yet overlooked the fact that torro rosso is running the very same wing. Redbull didn't miss anything on the front wing they have known about it from their junior team
jh199
32
Re: Red Bull RB15
Bill wrote:
20 Feb 2019, 16:09
Red Bull and Toro Rosso are running pretty dissimilar front wings. If anything, Red Bulls front wing is more like that of the Mercedes and the Toro Rosso is more like the Ferrari. Notice that the Red Bull upper element nearly reaches the top of the end plate whilst the Toro Rossos dips downwards significantly as it approaches the end plate. The Red Bull is producing a much stronger Y250 vortex as well
Chuckjr
37
Re: Red Bull RB15
Godius wrote:
20 Feb 2019, 12:46
Here it is google translated so you don't have to look it up.
"We hear from the Red Bull camp: As of today, the right rear wing adorns the RB15. "Before, it was a Montreal wing," jokes team principal Christian Horner. Meaning: A rear wing with too little contact pressure. The new produces more downforce in the rear. This makes it easier for the engineers to balance the car. Honda has swapped the engine for safety after the impact of Pierre Gasly yesterday. Investigations have shown that the engine was not damaged."
Watching F1 since 1986.
Re: Red Bull RB15
Via AMuS
ScrewCaptain27
577
Re: Red Bull RB15
AMuS
- Serj Tankian
zoro_f1
-2
Re: Red Bull RB15
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
