Notice that DRS was open in case of RedBull, this would make the car run with more rake initially.Seanspeed wrote: ↑21 Feb 2019, 14:17Here is the Red Bull, just for comparison. It is a very stark difference.
http://i.picpar.com/2zhd.gif
Oh, nice idea. They could have used the fact they have lower cog with lower-than-usual upper side impact structure and possibly other systems provide lower cog as well.
Of what i`ve read among a lot of other BS
I think their point was that on their philosphy of car, they couldn't really get it working and they couldn't generate enough downforce from the front of the car to balance the rear.Vanja #66 wrote: ↑21 Feb 2019, 15:12It's a bit too much BS from Merc saying they don't understand how Ferrari managed to get enough front downforce to balance the rear. With more rake, FW is closer to the ground and is providing a lot more downforce. And that's just to begin with. Optimizing endplate vortices, y250 vortex, aerofoils... Also, when you work your diffuser harder, whole car acts better, increasing the flow under the floor, barge boards and front wing as well. They all know that of course.
No way a F1 car is trying to have a high center of gravity. They always lover it as much as possible as it improves corner performance (less weight transfer). Movements of the car has little to do with CoG height and way more to do with suspensions settings. You can have softer suspensions, increasing the pitch, and use stiffer anti-roll bars to reduce the roll (you don't want roll because of suspension geometry changes and aerodynamics). The point is being able to have the right amount of pitch and being able to control it: here the importance of the hydraulic rear suspension.
No sudden "jumps", just small changes from the weight transfer.Seanspeed wrote: ↑21 Feb 2019, 14:17Here is the Red Bull, just for comparison. It is a very stark difference.
I'm just puzzled by the same thing. with their FW I would expect a (relatively) lower df RW. I don't understand how they get an overall balanced carBig Mangalhit wrote: ↑21 Feb 2019, 14:56It's.funny how to said he was surprised to see Ferrari make that front wing work with less AOA but not only it works but seem to balance with the barn door on the rear
yes, but I would say that, with all what are you referring to, with a smaller surface FW with respect for instance to merc, they would succeed in balancing a merc-style RW...but ferrari RW seems way more high DF one than merc RWVanja #66 wrote: ↑21 Feb 2019, 15:12It's a bit too much BS from Merc saying they don't understand how Ferrari managed to get enough front downforce to balance the rear. With more rake, FW is closer to the ground and is providing a lot more downforce. And that's just to begin with. Optimizing endplate vortices, y250 vortex, aerofoils... Also, when you work your diffuser harder, whole car acts better, increasing the flow under the floor, barge boards and front wing as well. They all know that of course.
