From AMuS regarding Mercedes' upgrades:
Mercedes has brought only minor modifications to Silverstone. This will be upgraded in Hockenheim again. It's a big upgrade. "This will be obvious to everyone," says an engineer.
I think one pair 'may' be due to the mounting points, but at least one pair is present because of the small radiator.101FlyingDutchman wrote: ↑12 Jul 2019, 12:41Those blisters are the mounting points which are FIA regulated so even though they can narrow the body work down around it, the mounting points are fixed in “space”
Mounting points for what?101FlyingDutchman wrote: ↑12 Jul 2019, 12:41Those blisters are the mounting points which are FIA regulated so even though they can narrow the body work down around it, the mounting points are fixed in “space”
The top mounts where the engine and gearbox/gearbox casing mate.henry wrote: ↑12 Jul 2019, 13:14Mounting points for what?101FlyingDutchman wrote: ↑12 Jul 2019, 12:41Those blisters are the mounting points which are FIA regulated so even though they can narrow the body work down around it, the mounting points are fixed in “space”
Looking at that picture again and comparing with the following:101FlyingDutchman wrote: ↑12 Jul 2019, 12:41Those blisters are the mounting points which are FIA regulated so even though they can narrow the body work down around it, the mounting points are fixed in “space”
Thanks. But I think you’ll find those connections are much further forward, 480mm behind the survival cell bulkhead.Blaze1 wrote: ↑12 Jul 2019, 13:47The top mounts where the engine and gearbox/gearbox casing mate.henry wrote: ↑12 Jul 2019, 13:14Mounting points for what?101FlyingDutchman wrote: ↑12 Jul 2019, 12:41Those blisters are the mounting points which are FIA regulated so even though they can narrow the body work down around it, the mounting points are fixed in “space”
