Racing Point RP19
Re: Racing Point RP19
Old:
New:
The radiator on top starts further in front now, maybe to slim down others to achieve a tighter engine cover.
zibby43
zibby43
613
MtthsMlw wrote:
24 Jul 2019, 20:17
Old:
https://cdn-1.motorsport.com/images/mgl ... tail-1.jpg
New:
https://maxf1.net/wp-content/uploads/20 ... o-AMuS.jpg
Great photo comparison.
Pyrone89
Are we seeing the Stroll takeover budget increase in action?
Tzk
Tzk
34
Probsbly yes. The team also pointed out that the car wasn‘t in a good state at the season opening due to the financial crysis last season. So we can expect further upgrades and hopefully a stromger rp19.
CLKGTR
CLKGTR
100
MtthsMlw wrote:
24 Jul 2019, 20:10
CLKGTR wrote:
24 Jul 2019, 15:19
Front wing centre section revealed - looks like it contains 10.92 kg balast in there.
Balast? So much? :o
This could be the weight of the FW without the nose I think.
Yes I think you are right... 10 kg balast in the front wing / nose was more common in mid 2000-s when cars used more than 50 kg of total balast if not more. But today 10 kg is probably way to much balast in the front wing, especialy when weight distribution window is so narrow.
ScrewCaptain27
577
CLKGTR wrote:
25 Jul 2019, 00:40
MtthsMlw wrote:
24 Jul 2019, 20:10
CLKGTR wrote:
24 Jul 2019, 15:19
Balast? So much? :o
It might also be the maximum amount of weight it is rated to carry.
- Serj Tankian
CLKGTR
CLKGTR
100
Might be. I would like to see the inside of other front wing middle sections to confirm that.
New engine cover
Old
digitalrurouni
digitalrurouni
With the rules stable for next year I really hope that this team can turn their fortunes around. We need them back in the fight big time!
New mirrors
Via AMuS
F1-dan86
F1-dan86
CLKGTR wrote:
25 Jul 2019, 12:55
Its painting related normally 2 stickers one pre and one post paint process showing weights of completed components, nothing to do with ballast weights just as simple as painted weight.
Red Bull like.
Ashwinv16
60
Sevach wrote:
25 Jul 2019, 16:54
https://pbs.twimg.com/media/EAU_fpIWsAA ... ame=medium
Red Bull like.
Nice update on the chassis side bringing better packaging to the car, providing a more Central weight distribution(Lower centre of gravity and corner weight distribution under load(Cornering, braking, accleratin etc..). This basically provided a wider set-up window allowing for the car to be more aggressively set-up for one-lap pace, while retaining similar characteristics to the previous design in the race. Small noticeable problems probably the big one being that the side-pod flow conditioner and the turning vanes probably need changing to eliminate any flow attachment issues the new shape has. Cooling seems to be rather aggressive considering the current Heatwave but radar says it will be cooler in the weekend, but you never know.
Halo not as bad as we thought
roon
roon
412
CLKGTR wrote:
24 Jul 2019, 15:19
By eye, using known FW and nose dimensions, a 15 x 4 x 2 cm block (120cc) may fit in there. 120 cc × tungsten density 19.25g/cc gives 2310 g or 5 lbs. If the pressure taps were removed, the full pocket might allow a block 25 x 4 x 2, weighing 3850g, or 8.5 lbs.
