diffuser wrote: ↑05 Aug 2019, 15:02
IvailoStefanovBG wrote: ↑03 Aug 2019, 19:07
Talking about 2019 WDC we should talk about luck too. Car is ok, engine is ok. If luck is on our side winning 2019 season is possible. All these years luck has been on Lewis's side. It's time for change now...
Luck is a 2 way street. When you say "If luck is on our side" , you could argue that it has been. Max has had several contacts with other cars ....If luck wasn't with him, all those contacts could have ended up in flat tires just after passing the opening of the pits. You could also argue that Max pushes his luck.
You want to talk about bad luck? Look at Bottas. How many times this year has someone made contact with him(not his fault) and he's ended up in the pits cause of it?
Last year certainly (Baku, France, Russia come to mind) but this year I wouldn't call him unlucky.
Sure, he lost a 2nd place in Monaco (he finished 3rd) and a 3rd place in Hungary through no fault of his own but nothing abnormal.
He has lost far more being off the pace or not having good starts or mistakes (Bahrain, China, Spain, Canada, UK, Germany).
