![Image](https://i.imgur.com/RI7BRLN.jpg)
Tire stress of 5. That's going to play a role in terms of race degradation.
Agreed re: pole, but Ferrari was nearly able to match Mercedes' DRS-and-slipstream assisted top speed up the Kemmel Straight... given lower tyre wear around Monza and use of softer compounds (which suit Ferrari better), I just don't see how Monza isn't another front-row lockout for Ferrari, and a more likely 1-2.Jolle wrote: ↑02 Sep 2019, 23:43Pole isn't as important as some other tracks. Top speed to fly by with DRS is. With the speed differential between the Ferrari, and Mercedes vs the rest at a track like this, they will be super super skinny.... whoever goes for pole, will loose to a race/overtake setup.
This is their advantage indeed. The car's acceleration is ridiculous, if you notice the gear changes, they fly from 3rd to 6th gear in a blink of an eye, it's like 4th and 5th last for less than a second. The PU has some serious power across its rev range.
If rain is forecast, Ferrari risk falling out of the top 10 frankly. They’ve been terrible in the wet essentially since 2009, for lord knows what reason. This year is obviously connected to downforce, but ‘17, ‘18? I don’t think so, but they were still terriblemkay wrote: ↑03 Sep 2019, 12:30Agreed re: pole, but Ferrari was nearly able to match Mercedes' DRS-and-slipstream assisted top speed up the Kemmel Straight... given lower tyre wear around Monza and use of softer compounds (which suit Ferrari better), I just don't see how Monza isn't another front-row lockout for Ferrari, and a more likely 1-2.Jolle wrote: ↑02 Sep 2019, 23:43Pole isn't as important as some other tracks. Top speed to fly by with DRS is. With the speed differential between the Ferrari, and Mercedes vs the rest at a track like this, they will be super super skinny.... whoever goes for pole, will loose to a race/overtake setup.
Rain could be on the forecast for both Friday and Sunday.
https://www.meteo.it/meteo/monza-5-giorni-108033
The probability for rain and thunderstorms on both Friday and Sunday is increasing.JPBD1990 wrote: ↑04 Sep 2019, 08:18If rain is forecast, Ferrari risk falling out of the top 10 frankly. They’ve been terrible in the wet essentially since 2009, for lord knows what reason. This year is obviously connected to downforce, but ‘17, ‘18? I don’t think so, but they were still terriblemkay wrote: ↑03 Sep 2019, 12:30Agreed re: pole, but Ferrari was nearly able to match Mercedes' DRS-and-slipstream assisted top speed up the Kemmel Straight... given lower tyre wear around Monza and use of softer compounds (which suit Ferrari better), I just don't see how Monza isn't another front-row lockout for Ferrari, and a more likely 1-2.Jolle wrote: ↑02 Sep 2019, 23:43Pole isn't as important as some other tracks. Top speed to fly by with DRS is. With the speed differential between the Ferrari, and Mercedes vs the rest at a track like this, they will be super super skinny.... whoever goes for pole, will loose to a race/overtake setup.
