Glad somebody else noticed. Did you hear how quickly he tried to make out Hamilton wasn’t a team player and how gutted he sounded when Davidson pointed out Budapest
I don`t think it`s pretty accurate that above graph ...MtthsMlw wrote: ↑27 Sep 2019, 09:13Cool diagram showing usage of ICE.
(this does not take in to account that you can reuse older ICE)
https://i.redd.it/7q17jjk7kzo31.png
MtthsMlw: „(this does not take in to account that you can reuse older ICE)“atanatizante wrote: ↑27 Sep 2019, 11:54I don`t think it`s pretty accurate that above graph ...MtthsMlw wrote: ↑27 Sep 2019, 09:13Cool diagram showing usage of ICE.
For instance, Perez has had failures on the 3rd Merc PU spec in Spa and in Monza. He also has had on at Singapore but in all the last 3 cases he received a 2nd spec PU which was brand new only in Spa ...
Then, as ziggy43 said quoting AMuS, Merc was using spec 2 at Singapore, which was the logical move, as GPR-A said before but here in the graph we could see they run the 3rd spec ...
Furthermore, Perez said on Sky in FP1 that his team will receive a new 3rd spec PU at the end of the season coz Merc has some issues with this spec, which echoes Toto`s half mouthed statement when he said on Spa that they run their engine slightly compromised and rumours saying also in Monza they didn`t run in the highest PU race mode (hence Lewis`s asking for more power when was trying to pass Charles) ...
This is the reason I watch FPs without commentary nowadays, just with FX sound. He is talking a lot and he is biased af.Restomaniac wrote: ↑27 Sep 2019, 11:08Glad somebody else noticed. Did you hear how quickly he tried to make out Hamilton wasn’t a team player and how gutted he sounded when Davidson pointed out Budapest
Ok, I got it! That`s the Perez and Kubica`s cases. But how about the 2nd spec Merc was using in Singapore which in that graph says it was the 3rd one instead?LM10 wrote: ↑27 Sep 2019, 12:02MtthsMlw: „(this does not take in to account that you can reuse older ICE)“atanatizante wrote: ↑27 Sep 2019, 11:54I don`t think it`s pretty accurate that above graph ...MtthsMlw wrote: ↑27 Sep 2019, 09:13Cool diagram showing usage of ICE.
I'm lazy I know, but what do they say in a nutshell?atanatizante wrote: ↑27 Sep 2019, 12:23Ok, I got it! That`s the Perez and Kubica`s cases. But how about the 2nd spec Merc was using in Singapore which in that graph says it was the 3rd one instead?LM10 wrote: ↑27 Sep 2019, 12:02MtthsMlw: „(this does not take in to account that you can reuse older ICE)“atanatizante wrote: ↑27 Sep 2019, 11:54
And regarding the Merc setup info where I got from, you should hear what Peter Windsor, Marc Priestley and some folks on Mixed Apex F1 podcast said about this matter on Youtube ...
Ferrari went for a full qualy setup like almost everybody did bar Merc and the reason was they were overconfident about their superior race pace in general but most of all in Singapore ... ...Bill_Kar wrote: ↑27 Sep 2019, 12:46I'm lazy I know, but what do they say in a nutshell?atanatizante wrote: ↑27 Sep 2019, 12:23Ok, I got it! That`s the Perez and Kubica`s cases. But how about the 2nd spec Merc was using in Singapore which in that graph says it was the 3rd one instead?
The graph is not about the spec but the amout of ICE in the pool for each event so to speak.atanatizante wrote: ↑27 Sep 2019, 12:23Ok, I got it! That`s the Perez and Kubica`s cases. But how about the 2nd spec Merc was using in Singapore which in that graph says it was the 3rd one instead?LM10 wrote: ↑27 Sep 2019, 12:02MtthsMlw: „(this does not take in to account that you can reuse older ICE)“atanatizante wrote: ↑27 Sep 2019, 11:54
Ok, my bad! Good to know, btw. ...MtthsMlw wrote: ↑27 Sep 2019, 13:48The graph is not about the spec but the amout of ICE in the pool for each event so to speak.atanatizante wrote: ↑27 Sep 2019, 12:23Ok, I got it! That`s the Perez and Kubica`s cases. But how about the 2nd spec Merc was using in Singapore which in that graph says it was the 3rd one instead?
