Jester Maroc wrote: ↑15 Oct 2019, 14:44
KeiKo403 wrote: ↑15 Oct 2019, 14:09
As for the Vettel false start, I guess technically it wasn't a false start, the rules say a false start is determined by the on board sensor triggering, as the on-board sensor didn't trigger it technically wasn't a false start. If the stewards would've handed a penalty out for that Ferrari would've took that to court somewhere, and most likely won, what they'd gain from doing that who knows but the stewards can only:
a. Give a penalty for breaking a rule
b. Give NO penalty for breaking a rule
What they can't do is give a penalty for not technically breaking a rule (unfortunately common sense can't prevail).
To be clear though, I didn't know the exact wording of the rules so I called that a false start because I saw a car move while the lights were still on.
I can't really understand the outcome they gave though where they said because he stopped he didn't gain an advantage. Look back to Russia, different crime, admittedly, but did Magnussen gain an advantage for running wide at T2, I don't believe he was directly battling with anyone?
You mean these, "Moved before the start signal is given, such judgement being made by an FIA approved
and supplied transponder fitted to each car" As others have pointed out according to the regulations Vettel could not be penalized, my issue is that this is a terrible precedent.
I don't understand why the results should be considered when reprimanding drivers for (visually) obvious penalties. Vettel not gaining an advantage does not change the fact that he intentionally moved prior to lights out.
well I was just venting my frustrations at this not being penalised because it couldn't be based on how the rules were written. Wasn't responding directly to anything you (or anyone else really) had already said.
I totally agree with you though about how the result of any incident seems to come into play. It shouldn't.
I'm gonna off on a wild tangent here but for the stewards to say no advantage was gained is as nonsensical as me saying if Vettel hadn't have jumped the start then he for sure would've crashed at T1 and left Japan with 0 points. As it is, what he did had a different affect and meant he ended up finishing second, ergo advantage gained.
It's through utterly stupid arguments like this that the 'result' of an incident shouldn't be taken into account as it's impossible to say what would've happened given a correct start.
For anyone wanting to respond to this argument, please note I'm not great at analogies or anything like that, it's more the meaning behind what I've tried to say instead of what I have actually said.
Also, it just so happens that this is about Vettel. I actually really quite like him so this isn't a personal attack on him. It's more the FIA/Stewards silly rules/decisions.
