That’s not the issue. If all they were doing was carrying more fuel in order to run higher modes longer, who cares? There would be no need to declare it because, so long as they didn’t use more than 110kg in the race it’s perfectly allowable.
The limit is not on fuel tank capacity it’s on fuel consumed in the race.jumpingfish wrote: ↑02 Dec 2019, 11:35Will teams carry more than 110 kgs of fuel if only 110 kgs are allowed? I mean for 115kg they should create the fuel tank volume = 164.286litres (if 1 Litre equals ~0.7kg gasoline) instead of 157.143l for 110kg. Extra tank volume requires extra space in car and also extra weight will slow them down.
Isn't the car getting a (random) fuel check the same way by draining the whole fuel out of the car, after the race? Also, teams need to keep a 1l sample for after the race.henry wrote: ↑02 Dec 2019, 11:36That’s not the issue. If all they were doing was carrying more fuel in order to run higher modes longer, who cares? There would be no need to declare it because, so long as they didn’t use more than 110kg in the race it’s perfectly allowable.
The issue is that the sum fuel_at_fill - fuel_after_race is checked against the FFS calculation of the same number. If you misdeclare the fuel_at_fill and you can run some extra fuel past the FFS undetected you can gain some extra power.
I don’t think that’s what was happening but it’s why the TD is there.
I beg to differ on this. While yes, a technical directive reflects the opinion of the FIA, viewing it as none-binding is not smart. Red Bull already proved this in 2014, when they exceeded fuel flow because they argued the official FFS did not work properly and used their own calculations, stating too the technical directive was not binding. The reality is that the technical directive is reflected on a regulation and therefore not following the directive results is a breach of said regulation.saviour stivala wrote: ↑02 Dec 2019, 12:04A technical directive is a notice to teams of how somethings has been interpreted by the FIA regarding the regulations. However, it is not a binding rule under the sporting or technical regulations. As a result FERRARI’s transgression was deemed a breach of FIA’S international sporting Gode. Namely article 12.1.1.I.
The amount of fuel put into FERRARI car 16 or any other car for that matter is not known because the amount (over and above or under the stipulated ‘110 kg’ race lights-out to flag used) put into a car being a free chose of the teams is irrelevant to the subject (is a free chose).
TD/014/19 require teams to declare the amount of fuel that they intend to put in the car for race before it leaves the garage. The maximum fuel flow, the maximum race fuel load and the fuel flow sensor has nothing to do with the above.
Telemetry data shows “fuel mass flow limit (100 kg/h) on each lap of the race as well as the maximum mass fuel load for the race used. Magnussen lost points at 2018 USGP for race fuel load use by using 0.1 kg too much on the last lap of the race. Ocon lost points at the same GP for using over the 100 kg/h fuel flow rate over only first lap of the race.richardn wrote: ↑02 Dec 2019, 12:08Also if you've got a way of getting more fuel in than seen by the ffs (ensuring samples are taken in troughs), you can also presumably get it to over read as well by ensuring the fuel peaks coincide with samples (obviously at lower throttle settings.)
My take is that if there was a trick being used, it was being used sparingly for qualification where they could hide any extra fuel use with the warm up and cool down laps. If you were systematically over using fuel and under reporting, you'd be caught out.
I wonder if they fuelled Vettel more heavily (older engine etc.) and accidentally put his values down against LeClerc's car. Would explain Vettel suddenly being told to save fuel.
EDIT: Scrub the last bit. Brain fade unless they filled LeClerc's car with the amount they intended to put into Vettel's car....
I also think it was some sort of human error in the measuring or reporting. Too many variables to get just right to consistently skirt the rules.henry wrote: ↑02 Dec 2019, 11:22Indeed. However it does rather require the opportunity to burn the fuel at the increased and undetectable rate. If, for instance there were a safety car or two, reducing the overall WOT time, there would be more fuel left at the end and a discrepancy between it and the FFS based sum.subcritical71 wrote: ↑02 Dec 2019, 11:00Which is on par for the after summer power boost that was seen.
I think finger trouble is a more likely cause than conspiracy.
then tell me ho can it be human error by the numbers that was dectected (if i am correct 4,88Kg) this number is strange if it was a solid number like 5kg or 7kg i could understand it but 4,88....it's a odd numbersubcritical71 wrote: ↑02 Dec 2019, 13:12I also think it was some sort of human error in the measuring or reporting. Too many variables to get just right to consistently skirt the rules.henry wrote: ↑02 Dec 2019, 11:22Indeed. However it does rather require the opportunity to burn the fuel at the increased and undetectable rate. If, for instance there were a safety car or two, reducing the overall WOT time, there would be more fuel left at the end and a discrepancy between it and the FFS based sum.subcritical71 wrote: ↑02 Dec 2019, 11:00
Yup, that number seems oddCapharol wrote: ↑02 Dec 2019, 13:24then tell me ho can it be human error by the numbers that was dectected (if i am correct 4,88Kg) this number is strange if it was a solid number like 5kg or 7kg i could understand it but 4,88....it's a odd numbersubcritical71 wrote: ↑02 Dec 2019, 13:12I also think it was some sort of human error in the measuring or reporting. Too many variables to get just right to consistently skirt the rules.henry wrote: ↑02 Dec 2019, 11:22
This is silly evidence in both directions. However, to take the most charitable interpretation of this point, the 4.88 was the error. If you believe this was a lazy human, such a human could write 105 "a nice human value", which would yield a "non human" 4.88 error if the true weight was 109.88. But the 'humanness' of a number is still silly evidence.
siskue2005 wrote: ↑02 Dec 2019, 13:36Yup, that number seems oddCapharol wrote: ↑02 Dec 2019, 13:24then tell me ho can it be human error by the numbers that was dectected (if i am correct 4,88Kg) this number is strange if it was a solid number like 5kg or 7kg i could understand it but 4,88....it's a odd numbersubcritical71 wrote: ↑02 Dec 2019, 13:12
Except that the telemetry data is actually showing a series of discrete fuel flow measurement samples which are being extrapolated to show the fuel flow rate per lap.saviour stivala wrote: ↑02 Dec 2019, 12:37Telemetry data shows “fuel mass flow limit (100 kg/h) on each lap of the race as well as the maximum mass fuel load for the race used. Magnussen lost points at 2018 USGP for race fuel load use by using 0.1 kg too much on the last lap of the race. Ocon lost points at the same GP for using over the 100 kg/h fuel flow rate over only first lap of the race.richardn wrote: ↑02 Dec 2019, 12:08Also if you've got a way of getting more fuel in than seen by the ffs (ensuring samples are taken in troughs), you can also presumably get it to over read as well by ensuring the fuel peaks coincide with samples (obviously at lower throttle settings.)
