Did RB get warnings during Qualify in Azerbaijan 2019 when Gasly was disqualified?dans79 wrote: ↑26 Dec 2019, 16:39You need to stop reading the ”rules” like they are some kind of absolutes, because they are not. Every thing has a tolerence.saviour stivala wrote: ↑26 Dec 2019, 15:01any one of those situations will result in the car being disqualified. if proof of a car being disqualfied for any of the above situations is needed i will gladly give that proof moderators permitting.
A momentary Spike of say less then two tenths of a second, will not get a car disqualified it'll get them a warning.
That is exactly what happened in 2014 to red bull in Australia that you so often like to reference as if it's some kind of validation of your opinion. Red bull was disqualified in Australia, because after multiple warnings they did nothing to rectify the issue, insisting there monitoring methodology was better than the ffs.
Horner said: Basically the fuel flow sensor sometimes get a little bit of oscillation and he got a good tow on his lap from I think it was a [Racing Point] so that puts it into the limiter in top gear and the resonance was just such that it dipped in and out of the limit by 0.02 of a gram or something. So in terms of performance, nothing, but obviously zero tolerance from the FIA.
https://www.racefans.net/2019/05/03/rac ... p-03-05-2/
