AMuS W11 technical analysis:
https://www.auto-motor-und-sport.de/for ... k-analyse/
Excerpts:
"According to the head of technology in the wind tunnel, the three large projects and the many changes in detail
have already confirmed the gain in downforce that the engineers had set themselves the goal of. Little has changed in air resistance, according to Allison. 'Aerodynamic efficiency is determined by the lap time, not the top speed. Those who generate more downforce with the same air resistance have become more efficient.'"
The engine is completely new. Mercedes had fallen behind Ferrari at least in the past two years. Renault and Honda had caught up. The former market leader did not want to rely on the fact that a second flow rate sensor slows down possible tricks. In the seventh year of the hybrid era, no stone was left unturned. 'We touched all systems. The efficiency of the internal combustion engine, the electric motors, the periphery of the engine,' explains engine chief Andy Cowell."
"Then Cowell goes into detail. Less loss in energy transfer from electrical systems. Less internal friction thanks to new coatings. Less heat radiation. The engine now runs well even at higher temperatures. The chassis engineers helped. They enlarged the cooling surfaces without taking up more space for the coolers themselves. All without adding up a gram or becoming an inch longer, wider or higher."
