e30ernest wrote: ↑06 Mar 2020, 09:05
CRazyLemon wrote: ↑06 Mar 2020, 06:52
Just_a_fan wrote: ↑05 Mar 2020, 21:53
Which also means it can't prove it didn't breach the rules. And, crucially, Ferrari wasn't able to prove it hadn't broken the rules.
That last bit is the bit that most people, including all Ferrari fans, are ignoring.
If Ferrari could
prove they were legal, there wouldn't be an issue would there? They would demonstrate it and the FIA would say ""they're legal". That they can't do so doesn't mean they're legal, it means they're probably illegal but the prosecutor (the FIA) couldn't prove beyond reasonable doubt that they were cheating.
The distinction is subtle (actually it isn't) but it's key to legal proceedings.
If I accuse you of eating the last pie and you say you didn't. I may not be able to prove you ate it, but my 'suspicion' still stands against you, also you may not be able to prove you didn't eat it. So then are you guilty because you cannot prove your innocence? I don't think it isn't being ignored, I think it's difficult to prove you didn't do something if there's no evidence. Surely if no evidence can be found against, evidence to exonerate could also be lacking.
That is a poor analogy IMO. The issue here is of a technical nature. Ferrari should be able to prove the legality of the engine in technical terms (i.e., measurements, computations, simulations) based on the actual engine unit. They for example do not need to prove they are only using x amount of fuel within the regulations, they need to prove how they are able to extract y amount of power given that fuel flow rate (if the issue is indeed in fuel flow).
No, that's where you are very wrong, they only need to prove that they comply with the control measures put in place as per the regulation.
There is absolutely no legal need for them to prove to anyone how they are achieving their performance.
That idea is absolutely juvenile and crazy.
Was any team ever required to disclose their performance achievements?
Should Mercedes disclose how they achieve good tyre warmup/management.
Should RB disclose what training they do to achieve fast pitstops?
Any investigation into legality follows this simple process.
1. Does the item conform to design specifications as set out in the regulation - Y/N
2. Are the required control measures in place as per regulation? - Y/N
3. Are the control measures operating as required by the regulation? - Y/N
4. Does the item operate within the control measures as stipulated in the regulation? - Y/N
If the findings of of all 4 points is yes, then the item is considered legal.
There is no need to prove anything beyond this.
There is no need to prove "innocens"
There is no need to provide performance details, as performance is not regulated.
Feelings of competitors are a not regulations.
Time to close this. "I don't like them therfore they are guiltily." mess.
