I don't have a problem with the chatting and what not, what I have a real problem with, is the constant need to dumb everything down to a toddlers level. My other major issue is with Crofty and his attempt to hype up anything that even looks like a possible pass attempt. Some times sky feels like I'm watching some low rate reality tv show.El Scorchio wrote: ↑08 Jul 2020, 14:23Absolutely- it's all about trying to drag casual/new viewers in with those features and endless talking heads and interviews rather than appealing to some of the more hardcore fans, (although i think they do a good job of building up the 15 minutes or so before a race start) and also it's very important for ad revenues for the broadcaster to have lengthy pre and post race shows. Anything live will get so many more viewers than if they shoved on library programming until 10 minutes before the race. It doesn't really cost the a great deal more to broadcast for longer from the track seen as most of the costs are the same regardless of how long you broadcast for. If they can eke out a 90 minute (ish) race into a 4 hour event, then they are making a hell of a lot more money. Unfortunately that does mean a lot of chat and fluff. But that's with all sports rather than just F1.
But if/when (strike out what does not apply) Merc is in 1/2 again with the rest of the field not keeping up, it might Just rear it’s ugly head again. Just kidding, and likely it will be Lewis in P1 This time around and Bottas I don’t see being quick enough to threaten Lewis (on equally old same compound tires).
Personally I think the electromechanical gremlins that affected several teams are because they through so many upgrades on the cars at once without any real integration testing. Upgrades that would have normally been bolted on over the course of 5 or 6 race weekends, all got put on at once.Sieper wrote: ↑08 Jul 2020, 17:29But if/when (strike out what does not apply) Merc is in 1/2 again with the rest of the field not keeping up, it might Just rear it’s ugly head again. Just kidding, and likely it will be Lewis in P1 This time around and Bottas I don’t see being quick enough to threaten Lewis (on equally old same compound tires).
that is undeniably true. We did have 9 DNFs to make that point. I feel it was a little too convenient (and a smart way to keep your drivers at bay without totally upsetting them in race one) but that is just how it works in my head. I immediately felt that way when Lewis started getting really close and he was sort of called of. At first Bottas still kept using the kerbs and so the team made it abundantly clear to him as well (otherwise Lewis might not have accepted the call/ask not to use the kerbs).dans79 wrote: ↑08 Jul 2020, 17:40Personally I think the electromechanical gremlins that affected several teams are because they through so many upgrades on the cars at once without any real integration testing. Upgrades that would have normally been bolted on over the course of 5 or 6 race weekends, all got put on at once.Sieper wrote: ↑08 Jul 2020, 17:29But if/when (strike out what does not apply) Merc is in 1/2 again with the rest of the field not keeping up, it might Just rear it’s ugly head again. Just kidding, and likely it will be Lewis in P1 This time around and Bottas I don’t see being quick enough to threaten Lewis (on equally old same compound tires).
Very good points. I may despise it, but you are right that the reality is that for F1 to exist it needs viewers and getting new viewers is a much better focus for strategy than retaining existing ones.El Scorchio wrote: ↑08 Jul 2020, 14:23Absolutely- it's all about trying to drag casual/new viewers in with those features and endless talking heads and interviews rather than appealing to some of the more hardcore fans, (although i think they do a good job of building up the 15 minutes or so before a race start) and also it's very important for ad revenues for the broadcaster to have lengthy pre and post race shows. Anything live will get so many more viewers than if they shoved on library programming until 10 minutes before the race. It doesn't really cost the a great deal more to broadcast for longer from the track seen as most of the costs are the same regardless of how long you broadcast for. If they can eke out a 90 minute (ish) race into a 4 hour event, then they are making a hell of a lot more money. Unfortunately that does mean a lot of chat and fluff. But that's with all sports rather than just F1.
Put like that, it's hard to disagreeEl Scorchio wrote: ↑08 Jul 2020, 14:23I like to look at it that it might capture more new viewers and keep the sport as popular as it can be, even if i don't really watch it myself!
If it result different it will be very interesting. Because of many unexpected retirement it will result different. but if.it result same it may be boring just in second race is spite of long break
The dumbing down thing is much worse in American motorsports TV coverage. It's been that way since the '80s, and probably since before then.dans79 wrote: ↑08 Jul 2020, 16:43I don't have a problem with the chatting and what not, what I have a real problem with, is the constant need to dumb everything down to a toddlers level. My other major issue is with Crofty and his attempt to hype up anything that even looks like a possible pass attempt. Some times sky feels like I'm watching some low rate reality tv show.El Scorchio wrote: ↑08 Jul 2020, 14:23Absolutely- it's all about trying to drag casual/new viewers in with those features and endless talking heads and interviews rather than appealing to some of the more hardcore fans, (although i think they do a good job of building up the 15 minutes or so before a race start) and also it's very important for ad revenues for the broadcaster to have lengthy pre and post race shows. Anything live will get so many more viewers than if they shoved on library programming until 10 minutes before the race. It doesn't really cost the a great deal more to broadcast for longer from the track seen as most of the costs are the same regardless of how long you broadcast for. If they can eke out a 90 minute (ish) race into a 4 hour event, then they are making a hell of a lot more money. Unfortunately that does mean a lot of chat and fluff. But that's with all sports rather than just F1.
same for me. Especially knowing from experience with Sky Germany, how poorly F1 coverage can be done: one guy at the track, doing some completely content-free interviews, and a commentator with no knowledge at all, covering the race from the studio.
