F1Krof wrote: ↑28 Jul 2020, 00:07
Too early to say but. I expect RB to raise their game. I'm not buying this Mercedes dominance to be honest. They hit the sweet spot and it was just 2 different tracks remember. That RB looks handful in Qualy but very fast come race trim. So, let's just wait and see.
In Hungaroring most of us though it'd be Max on pole, it turned out to be different.
The number of circuits doesn't really matter. You can look at the data from corner types and straights and extrapolate. The W11's greatest strengths this year have been fast corners and straights. That's where they've been consistently faster than everyone in the field, including Red Bull. Silverstone is a power-sensitive track filled with fast corners.
Mercedes and its drivers still have to execute, but the car's performance should be very strong there.
Mark Hughes had an interesting article out today that touched on Red Bull's performance.
https://www.motorsportmagazine.com/arti ... -f1-rivals
Hughes spoke with an aerodynamicist to try to understand Red Bull's struggles:
“Since the regs changes of 2019 [principally the simplified endplates and the restriction of the under-nose vanes], the vortices you’re creating at the front end of the car can be quite unstable. Especially if you are running a lot of rake. The car is articulating around the front bib of the floor and that rake is increasing quite quickly as you slow down – and that makes that whole flow quite volatile. You can see in the tunnel the vortices can even suddenly switch from inboard to outboard. It could be the amount of steering lock or a crosswind – it’s so on the edge.”
