ESPImperium wrote:Intresting, could there be shark gills put in there for this purpose as they are close to the cars centre line???djos wrote:from what i've been reading, this panel that forms part of the "tail" can be removed for extra cooling when needed:
One thing i have a concern about is the exaust location to where the suspension is, shurley the hot gasses could make the suspension fail???
Don't call me shurley
The front wing is a thing of beauty so far, i think the front end is the best looking aesthetically so far.
Does Red Bull use their own gearbox? Or do they use Renault's one.Moanlower wrote:It appears to be a gearbox problem accordng to Newey.
They use one from an old Ford Cortina.ackzsel wrote:Does Red Bull use their own gearbox? Or do they use Renault's one.Moanlower wrote:It appears to be a gearbox problem accordng to Newey.
I would like to know myself. I read that RBR attached suspension arms onto their gearbox though. Don't think Renault did that, even if it turns out to be the same box.Agerasia wrote:They use one from an old Ford Cortina.ackzsel wrote:Does Red Bull use their own gearbox? Or do they use Renault's one.Moanlower wrote:It appears to be a gearbox problem accordng to Newey.
Well, at least that's a design that has proven its self.Agerasia wrote:They use one from an old Ford Cortina.ackzsel wrote:Does Red Bull use their own gearbox? Or do they use Renault's one.Moanlower wrote:It appears to be a gearbox problem accordng to Newey.
Quite a bit of difference on the front suspension between Vettels car on track, and Webbers car in the studio shots.benjabulle wrote:All the photos in High Resolution the rear end is :
http://www.gurneyflap.com/formule109.html
The gap was about 25 to 30 Bhp if i'm not mistaken. Not too difficult to overcome when you are allowed to. Who knows, maybe they are a little ahead now.ackzsel wrote:Aside from reliability, will this (beautiful) car stand a change with the Renault engine? Maybe it's to early to judge, but I can't image that Renault's modifications will close the gap with other engines completely.
